getindirty
Rock is great but pricey and unless it is the crusher run it is tough to compact. Sand works very well and lowers your install cost. The slab foundation idea's noted does not need to be applied as you are building a pole barn. The concrete will be "floating" inside the shed and not bearing any of the construction weight. I will agree that you should install a vapor barrier and consider a under slab and perimeter insulation if you want it heated. It will raise the concrete height 2". Rebar is awesome if you are parking a dump truck on it. Wire mesh (remesh) works well for everyone else. Tell the contractor building the shed where to set the rim board based on slab insulation and concrete thickness. I used a mini-excavator to dig the perimeter insulation after the framing was complete (it took two days to install).
Insulating Slabs
http://www.eere.energy.gov/buildings/building_america/pdfs/38309.pdf
Good luck.
Insulating Slabs
Good luck.
