gravely L oil coming from breather cap
   / gravely L oil coming from breather cap #1
jb4020
I have a '51 L with the old 5 horse engine and it constantly sprays a mist of oil from the breather cap. The gravely runs well and i use it alot with no problems. I know if i take the cap off i can see the oil pump stream of oil and my guess is it just sprays some out. It sure make a mess any ideas? Thanks
   / gravely L oil coming from breather cap #2
Is the breather cap clean?
Is the gasket on the breather cap in good shape?
Do you think you have normal oil pressure? Not all Gravelys have an oil pressure gauge.
Thanks for the reply. The cap appears to be clean. I didnt think about the gasket that could be the whole problem. I think the tractor has good oil pressure mine does not have a gauge although i would like to add one. If i pull the breather cap off after i start it as the directions say there is a strong stream of oil shooting out of the little nossle. Thanks
   / gravely L oil coming from breather cap #4
The Ls all tend to blow out some oil vapor. It's the nature of the beast. Unlike modern engines and tractors, the L has no PCV system. Any blowby, the actual air that is displaced by the piston movement, and any exhaust products that get blown by the valve stem guides ends up coming out the breather cap. 30 cuin of air move just because of the piston movement. The newer caps do a better job of filtering it out but even they have their limits.
Well that makes me feel alot better. I have the breather cap with the wire mesh inside. Any idea what the oil pressure should be i want to add a gauge. Thanks
   / gravely L oil coming from breather cap #7
Unless it has been upgraded to a high volume pump, a 30 PSI gauge is fine. The relief is set at 15 PSI.
Thanks for all the replies! I would like to upgrade to the high pressure pump. I believe this is possible. Is it just a matter of taking the old one off and replacing it? And any ideas where to get one? Thanks
   / gravely L oil coming from breather cap #9
How hard it is to convert will depend on if you have a spin-on oil filter or not already. The high volume pump itself simply replaces the low pressure one. You do have to remove the pulley to get to it. If your tractor is an electric start model, then the starter clutch has to come off. Once the pump is on, you need to replumb the tractor for the canister filter replacement with the spin-on type. Oil line that was to the block now needs to run from the pump to the filter. Output of the filter then goes to the block and relief valve. Gauge needs to be changed to a 50 or 60 PSI unit as at WOT and cold, pressure can hit 45 PSI. New gauge is installed just before the filter input.
E-bay has the items used on occasion or you can get them from Richard's Lawn and Garden in Spencer, WV. Gravelyparts.com Any Gravely dealer can order the parts from Gravely for you but Richard's normally has the best prices. If you run into any problems, PM me and I can look up the part numbers in Gravely's dealer's website.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A55852)
Pallet of...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
2014 Ram 1500 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 Crew...
