Tiller Gray Market Tiller
   / Gray Market Tiller #11
I had to cut the length on the PTO shaft before the 48" kubota tiller would fit to my 1500D Yanmar tractor. It was quite simple. I made the measurement with the tiller attached to the tractor, then took the PTO shaft down to a local shop where they cut the shaft with a chop saw. Works great now.
   / Gray Market Tiller #12
For the benefit of anyone else faced with the problem of replacing seals and bearings in this tiller, here are part numbers:
#4 - Lower Drive End Ball Bearing (Behind the Large Sprocket) : Kubota 08101-06209 or NSK 6208
Upper Tapered Roller Bearing (Behind the Small Sprocket) : Kubota 08711-30207 or KOYO 30207JR
#6 - Lower Drive End Oil Seal : Kubota 32218-55350 : NOK A02693E
#9 - Dust Cover (big washer behind oil seal) : Kubota 70431-55310
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
