GREASE... every 10 HOURS?
   / GREASE... every 10 HOURS? #41
I'm glad I'm not the only one to notice this! I've been considering finding some thinner #1 grease instead of the normal thicker #2 just for that dang pedal. Sometimes it returns so slow if I hop off the tractor quick the "no one on seat" switch kicks in killing the motor:eek:
you jump off still moving!?:eek: watch out for saftey police!!!!:p
on the serious side, Yeah I noticed this as well. I also tightened up the jam nut to provide more return tension on the spring to prevent this from happening. It took about 20 hours or so and two greasing with the lighter grease to work out the thicker stuff on that dang pedal. This coming spring, I think I am gonna take the floor pan off and see if I can take that linkage apart and clean.
   / GREASE... every 10 HOURS? #42
I would watch overgreasing because you have to wipe up everything because grease will collect grass, sand, grit, and other natural bits that will actually grind the parts more.
Just be careful.
   / GREASE... every 10 HOURS? #43
Newer tractors generally have electronic hours meters and are based on how long the ignition switch it on.
Topic drift, but that's not very precisely stated. Most new tractors have RPM compensating hour meters. Last Bobcat I drove had one. Rented a big Ditchwitch rock saw last week and it had a compensating meter.
Just "low-end" tractors (like the BX) have a straight clock.
   / GREASE... every 10 HOURS? #44
You can tell when a joint "needs" grease if it's dry or not,use the proper grease for the application and one don't need to grease as often.
   / GREASE... every 10 HOURS? #45
Hey, I resemble that remark! :laughing:
Wish I had seen this thread on grease before I posted my recent questions and pix about grease.
   / GREASE... every 10 HOURS? #46
I really appreciate everyones input!! I think I will continue with the every ten hour thing! Just have to buy more paper towels. As soon as the weather warms up a little more I plan on giving her the first pressure wash she ever had. This hopefully will get rid of excess grease and I will be able to start all over again.;)
Sorry to change to subject...
Wow, seeing your dolphins really brings back memories. One thing I really regret is not working on my ESWS and ASWS qualifications while I was stationed on the USS Nimitz.
   / GREASE... every 10 HOURS? #47
O.K. I know maintenance is very important and I am religous when it comes to maintenance. BUT...... my LA463 loader says to grease all the fittings every ten hours. I have no questions about what kind of grease to use , or how to do it, my question is........How do you know when you have actually put ten hours on the loader? I have 58 hours on the tractor now and have been greasing every ten. With 60 hours coming up I have gobs of grease all over the pins and pivot points.:( (You can't even lean against the arms without getting grease on you.) I use the loader a lot but not the whole time the engine is running. What do you guys do?
Simply put...I've never experienced a failure of any kind due to "overgreasing".
   / GREASE... every 10 HOURS? #48
   / GREASE... every 10 HOURS? #49
Well, I don't keep pouring fuel into my tank until it runs over just to make sure I have enough and I don't over grease just to be on the safe side, I use the proper amount, no more and no less.
   / GREASE... every 10 HOURS? #50
I usually grease my whole machine whenever I start a new job, or just when I think of it and have nothing better to do. I keep my backhoe attached all the time, so between the tractor, backhoe, and bucket, there's roughly a thousand grease fittings to hit. I admit to being an overgreaser too - even though I try to keep the excess goop wiped up, all I have to do is think about standing next to my machine and I invariably find a blop of grease on my clothes somewhere. I hate when that happens.
JayC
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
bad boy zero turn 72 (A56859)
bad boy zero turn...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
