Grease Gun Pains
   / Grease Gun Pains #11
Best way to remove it is to put the head between something soft like between a pair of dual tyres on a truck or simmilar and turn the cartridge tube counter clockwise . Be very carefull if you use a vice to hold the head .
   / Grease Gun Pains
OK...Brute force and ignorance = 1 Reading instructions = 0
The head came off and I loaded it just fine. I should have remembered the "mans rule for assembly" instructions..naaaa I can figure it out myself :D
   / Grease Gun Pains #13
ray66v said:
I am still looking for the "Holy Grail" of grease guns. I have 4 different ones, including 1 that is a brand name air powered unit. Every one gives me grief of some sort.
I am actually learning to like my Harbor Freight electric one.
There are a couple of tricks.
1. Make a loop of rope or baling twine which is about 8" long when doubled. To retract the plunger put one end of the loop around the T-handle and the other end on one of the hooks on your bucket, or other firm point so you can pull the grease gun with both greasy hands.
If you just hook the T-handle in the grab hook on your bucket it will break.
2. Priming these things is a pain in the donkey. So, outsmart the grease gun. When you take it apart to put the very first cartridge in it, before it is coated in grease, look at how the high pressure pump works. It is just a plunger running in a cylinder, and you can look right into the intake port in the cylinder, which is built into the head of the grease gun.
Take your finger and build up a lump of grease about the size of an apricot right on top of the intake port the first time you use the gun, before you insert the cartridge and screw the cartridge carrier back into the head. This eliminates the need to prime the gun.
After the first time, the lump can be smaller, about the size of a walnut.
Once I figured out this little trick, I never had to prime the gun again, which makes things much faster and eliminates the need to "bless the grease", which my wife prefers, and so does the pastor.
   / Grease Gun Pains #14
I use a simillar proceedure to bleed a hand gun Curly . When the gun is empty i unscrew the barrel a couple of turns and pull out the plunger , this allows air to enter the chamber and eliminates the vacuum . Then i unscrew the barrel and with the threaded end of the barrel i swirl the remaining grease in the head to cover the air hole in the grease above the piston . When i replace the barrel i only screw it on a couple of turns and release the plunger . This expels the air from the new cartridge via the barrel threads , i give the head a jiggle to help . After tightening the barrel i pump the gun into a piece of rag to bleed it . Its the easiest way to get a gun working again , trying to use the bleed screw is a non event as blobs of grease can block the escape of the trapped air .
   / Grease Gun Pains #15
This sounds like a plan, I will try it next time.
   / Grease Gun Pains #16
The best way I've found to keep air out when reloading the gun is to get a little grease on me. When I load the gun with a new tube I save the spent tube and finger out the little bit of grease thats left, be careful not to cut your finger. I then fill and mound the new tube (thats in the gun) with this left over grease. After doing this when you screw the head back on it forces out the air without needing to bleed or jack around with the gun. Usually a little grease will need to be wiped from the base of the head. I learned this trick because I'm tight and hated throwing away that little bit of lube in the spent tube. After that first time I found it got rid of the air as well. I've done this for years and it drives me nuts when I see someone load a gun and then fight an air pocket.
   / Grease Gun Pains #17
Surewhynot said:
OK so the rule is you have to be smarter than what you are playing with! I am going to use brute force and ignorance and force the head off so that I can insert the tube, put the head back in, release the T handle and use the gun as it was intended. I guess I was not using enough force to remove the head assembly. Thanks to everyone for the help. I was correct in my thinking, just have to put some force into it I guess. I will let you know how it turns out.
If you do much greasing, buy a Lincoln 14V (18V better) Little pricey for a hobby, I think I paid $200 for the kit, it loads the same as a regular gun, but it takes most of the work out of greasing. I agree with the others, you took off the wrong end. I have owned a bunch of grease guns, but I never have seen one that you cant unscrew at the head.
Good Luck and keepem greased
   / Grease Gun Pains #18
You figured it out in couple of tries and that's pretty smart!
There are many stories regarding the new grease gun owners. I remember that when I first tried to load my first tube, it took couple of hours! Grease coated both hands, up to my elbows, over my shirt, and my brand new cement barn floor! By the time I brute forced the whole thing in place, there was only a third tube of grease left in the tube. But, I do remember the sense of accomplishment ....!
I bought a battery powered Lincoln shortly after that encounter!
   / Grease Gun Pains #19
RickB said:
Well we used to sell Plews at work and they load from the top like any other grease gun. If you can't figure out how to load the top end, go get a Lincoln. Plews stuff is low end junk anyway. The barrel is the only thing that's going to keep the spring in alignment under compression.
Ditto,on the Lincoln grease gun.coobie
   / Grease Gun Pains #20
Some grease guns have a little bleeder valve. Others have a set screw for getting the air out.
The method I use is to lock the handle so I can put much more pressure on the grease than the spring does and then pump the gun. That will get rid of the air. You can do this with the gun on a Zerk so no grease is wasted. Warm grease also makes things go easier!:D :D :D
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
CATERPILLAR ARTICULATED WATER TRUCK (A60429)
CATERPILLAR...
DEUTZ MARATHON...
