Grease gun ?
   / Grease gun ? #21
I have had a Snap On (which is a Lincoln I believe) for 20 years. It gets used almost every day, and has never failed. It is the kind that can be pumped with one hand, and has a long flex hose to connect to the fitting. I would recommend it over the handle pump kind because of it's ease of use. If all I did was grease equipment all day I would have a powered version of this. For modest use, I would not spend hundreds of bucks. We have a wheeled drum fed air powered unit that never gets used anymore cause the hand powered ones are quicker.
   / Grease gun ? #22
I keep it regulated at ~110. May have possibly even used it at full tank pressure 125 lbs (Sometimes I forget to reset the regulator!). I bought it at the NAPA on Main Street in Hampden. If you are in the area, stop by and I would be happy to demo it for you.
Pallet Fees (A50775)
YALE NR035DANM247F091 WAREHOUSE STAND ON FORKLIFT (A51242)
YALE...
Concrete Trowel (A47384)
Concrete Trowel...
2008 JLG 450AJ SII SKYPOWER TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ SII...
2008 PRENTICE 2410 LOG LOADER (A51242)
2008 PRENTICE 2410...
