Grease left in my grease gun
   / Grease left in my grease gun #1
Davidsan
AL
Kubota M9540 w/FEL
Does anyone else suffer from having residual grease left behind the plunger when your gun runs out? Seems like everytime I change tubes and I retract the spring loaded rod, grease escapes past the plunger and oozes and oozes out of the hole the rod slides through. I end up "wasting" a lot of grease - I save it and use it for other applications outside the gun but it is still frustrating to not get the whole tubes worth through my gun. I use a Lincoln pistol grip gun and and older Sears gun. I use Chevron Ultra Duty No.2 grease (red stuff). It's real good grease (very stringy) but don't remember this happening with the cheaper Tractor supply grease (black) that I used to use. I wonder if the grease is not viscous enough.
Just wonder if this is an anomaly or do others experience this?
   / Grease left in my grease gun #2
I see it occasionally on customers guns. Seems to be individually g.gun-specific rather than common to all guns of a particular brand. Like you, I also detest the mess and waste.
Next time you need to reload - Dismantle the whole plunger from the gun tube and check that your follower-washer is not damaged.
   / Grease left in my grease gun #3
There's two places where grease can bypass the plunger...at the main lip seal and also where the rod attaches to the plunger.
   / Grease left in my grease gun #4
I had a grease gun that ended up with that problem. I simply threw it away and bought a new one - Lincoln. End of problem.
   / Grease left in my grease gun #5
I've had the problem but it's usually caused by the plunger inside the cartridge being damaged. I seam to get either metal or plastic plunger stye tubes. The metal ones seam to dent real easy and allows grease to pass by.
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
500 Gallon Fuel Tank (A50775)
500 Gallon Fuel...
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI GY-PG72C...
2020 FREIGHTLINER M2 SINGLE AXLE BOX TRUCK (A56129)
2020 FREIGHTLINER...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
