Grease; Please educate me
   / Grease; Please educate me #11
dgdave1 - Yes, a moly fortified grease is highly suggested in high impact/extreme preasure applications like bucket pins on backhoe's. One reason Caterpillar spec's it for their equipment. In boundry lubrication situations you at least have the solid film lubrication of the moly.
dknarnd - Nope, your not the only one. Lot's of people have leaky grease guns. That's oil seperation. Some greases tend to bleed grease more than others. Some have very high seperation rates while others show little to no seperation.
As far as compatability goes the Paragon 3000 is a Calcium 12-Hydroxysterate based grease. This base grease is compatible with everything but Polyurea and is borderline compatible with Calcium Complex. That's a nice bonus of the Calcium 12-Hydroxysterate base greases, their high degree of compatability.
   / Grease; Please educate me #12
whats your thoughts on marine greese diesel?
id take apart my greese gun and see whats in it but thats just to messy,lol
seriously marine greese good or bad, I have a fel and bh on a bx.
"red and tacky" sounds like a good movie :D
   / Grease; Please educate me #13
Most greases that are marketed as "marine" grade grease are nothing more than a highly water resistant grease. Use caution when using marine grade grease on heavy equipment. Some of them do not have very good extreme preasure properties. It's alway's best to check the spec sheet. Timken OK load rating should be at least 60-70 lbs with 80+ lbs prefered for heavy equipment and implement lubrication. Marine greases are a specialty nitch type grease ment to service the marine industry. They are frequently used on boat trailer wheel bearing's that require a very high resistance to water since the trailer is backed into the water and the wheels/hubs get submerged in the water.
DeiselPower - been checking out various grease specfications and the TRC offerings certainly would be nice to have. The only problem I see is the packaging method that it is offered. I would think that the average hosehold consumer would be well stocked with between a 6 and 12 tube carton.
Which brings me to another question. Is there a shelf life on grease? The TBN fourm has already offered a large thread on the shelf life of oils but what about grease?
   / Grease; Please educate me #15
Unlike oils that all have a similar shelf life grease shelf life varries greatly. Mainly due to the wide assortment of greases and their different oil seperation rates. A grease that resist oil bleeding under most conditions does not crack, harden or become thin.
The buckets and drums I have in the shop and in my mobile service trucks are not that old but the drum I have at the house has been there for probably close to 7 years or so now. It shows no visable signs of oil seperation or cracking. It's the Moly 880 Crown and Chassis grease (not suitable for wheel bearing's).
   / Grease; Please educate me #16
Both are available in 50 tube cases for the following prices;
Paragaon 3000 Moly Lithplex
$356.00 $373.00
That stuff must be really good. Anybody know where I can buy smaller quantities? I don't think I willl live long enough to use 50 tubes?
Thanks, Les
   / Grease; Please educate me #17
50 tubes of grease is equivelant to 45 pounds of grease. TRC in addition to selling grease in 50 tube cases also sels it in 45 pound (6 gallon pails). The cost of the pail is considerably cheaper then the tube price. You can buy a pail of either and a bulk filler pump for your grease guns and it's still cheaper than the 50 tube/case. I very rarely sell grease in tubes.
----------------------50 Tube/case----------45 pound/6gallon pail
Paragon 3000----------$356.00---------------$235.80
Moly Lithplex----------$373.00---------------$289.35
   / Grease; Please educate me #18
DieselPower,
What's your opinion on Mystic JT-6??? Everything i've read says it's excellent and has a dropping point of 550 degrees, a timken ok load in excess of 80 pounds and you can usually buy it for around $2 or so a tube. What can you tell me about it?
   / Grease; Please educate me #19
First I'm not a big fan of anything Citgo, it's the anti-American President of Venezuela, Hugo Chavez aspect. Now with the politic's out of the way. :) Citgo Boycott Headquarters
There are two different JT-6 greases. Their Multipurpose and Hi-Temp greases. I take it that your talking about the Hi-Temp grease because the Multipurpose only has a Timken OK load rating of 55 while the Hi-Temp in NGLI #2 has a Timken OK load rating of 80. While it does have a 550 degree F. dropping point it's working temperature range is only -10 to 325 degrees F. It shows oil seperation of 1 (that would be the oil that runs out of your grease gun). They don't show worked penetration rating's over 60 so I get the feeling it thins out in the 10,000 and 100,000 worked stroke test.
Overall it's rating's don't look to bad for off the shelf grease when compared to other off the shelf store greases.
   / Grease; Please educate me #20
What about the Mystik Synthetic Blend grease? I just picked up a couple tubes of that for $3 a piece. It wasn't much more than the regular stuff and I figured it might be good in cold weather situations. They claimed a pretty low bottom end on the working temp on the tubes... forget exactly what it said... something like -65 I think.
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
Jaw Crusher (A59228)
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
