grease question
   / grease question #1
aking
'68 Minneapolis Moline U302, '43 Case VAC, '46 Case VAC, '52 Case DC
Hello everyone, first time posting on here. I've been looking into switching over to Schaeffer's grease but I'm not sure which one I should use. I have been using Case IH grease. I mostly use it for greasing tractors, water pumps, and just other things around the farm.
Thanks in advance!
   / grease question #2
What application you plan on using this grease in? wheel bearings,pins/bushings etc??? what grease you looking at?
i use nothing but Schaeffer's #238 in our equipment at work and my personal stuff, outstanding product that protects well and reduces wear dramatically.
**edit**
i see now you listed applications,anyway if you operate in none cold temps? mostly I'd use 238 on everything but wheel bearings/bearings as it's loaded with tackifiers and may lead to bearing skip(but i have used it with out issues) but anything that "slides" like pins/bushings,5th wheels,implement lift areas etc,this grease will shine there.
if you also operatet in winter or cold temps you may want to switch to
#274 NLGI #1 or 0
   / grease question
I was looking at either # 238, 221, or 229. I will be using it for some bearings on equipment but not wheelbearings. Mostly just a multi-purpose grease for everything.
   / grease question #4
All should work fine for what your doing 221 is just 238 with out the extra tackifiers.
229 has less Moly, i believe 238 and 221 have 5% witch is important for me as that's your anti-wear additive in this grease, all have an aluminum complex thickener witch resists water wash out and pound out vs. a lithium base, just an excellent excellent grease you wont be disappointed.
IMO go with 238 or 221.
   / grease question #5
The 221 meets Catapiller MPGM which is a 3% Moly spec. It is an exceptional grease and will pump very well in cold weather.
   / grease question #6
I believe Caterpillars spec's is 5% for EP aplications also,any rate this grease will do the job.
correct 221 is 3% 238 is 5%
   / grease question #7
Yes... You are correct. Cat's spec for pin's and bushing's is 5% Moly. Otherwise, 3% Moly. The thing that sets Schaeffer apart is the Aluminum Complex thickener and will outlast any Lithium Complex thickener for better, longer lasting performance.
   / grease question #8
You got that right lithium will actually mix with water and cloud up in your hand anyone serious about greasing there equipment should use a better thickener for sure.
   / grease question
Thanks for the input everyone. :thumbsup: From my understanding the aluminum complex will mix with the lithium based greases that I've been using before?
   / grease question #10
Aluminum complex is compatible with lithium complex yes..
but to get the full benefits of the AC grease make sure you push all the lithium out.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2017 F-550 Bucket Truck (A51039)
2017 F-550 Bucket...
John Deere D110 42in Riding Mower (A49461)
John Deere D110...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
