grease your balls or not
   / grease your balls or not #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I know this is a personal question but do you grease your hitch ball or not?
   / grease your balls or not #2
Yes. With the heavier BP trailers I pull, upto 25,000#, I have seen them loosen. I use Reese Ball Lube. Same jar has lasted me 10 yrs.
Chris
   / grease your balls or not #3
Sure helps it stop squeaking. I grease it with clean grease each time before hitching up the gooseneck. Afterwards l wipe it all off and stow the ball under my rear seat. I wipe out the gooseneck coupler also, as it usually has some dirt blown up in there.
hugs, Brandi
   / grease your balls or not #4
Just so they don't rust.
More important - Are your balls big enough? Don't use a 2" where you need 2 5/6. And almost ALL balls in the big box stores are 6,000lb rated balls, or less, even the 2 5/16.
   / grease your balls or not #5
It will noticeably reduce sway.
   / grease your balls or not #6
I don't. Grease attracts dirt and the dirt will grind away and chafe your balls.
   / grease your balls or not #7
Short trips no, but when I am going 20 miles or more I will. CJ
   / grease your balls or not #9
Critical to use the right kind!
   / grease your balls or not #10
U don't have to but I have a pull truck that has a 1,300,000 miles and the gooseneck ball has major wear .
Sent from my iPhone 5 using TractorByNet
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2012 Toyota Prius Hatchback (A55853)
2012 Toyota Prius...
24" PIN ON BUCKET (A52707)
24" PIN ON BUCKET...
2017 FORD F550 XL SERVICE TRUCK (A57192)
2017 FORD F550 XL...
