Grease zerk replacement.
   / Grease zerk replacement. #1
BufordBoone
Platinum Member
Tuscaloosa, Al
Kubota L5740 & M7060
Got a grease zerk that won't take grease. I've got one of the tools that you put oil in and tap the piston to clean the zerk. Although it has worked on others, it has not on this one.
I've been unable to unscrew it using wrenches and, next a pair of vice grips.
It is the zerk to grease the quick attach piston for the bucket/grapple, etc.
Anyone think a bit of heat might help?
Any other ideas?
Thanks.
   / Grease zerk replacement. #2
Are you able to slide the piston partly out and pump grease in to blow the blockage out, then push the piston back in?
Some times a pin on the loader will refuse to take grease and this method is very effective for me.
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
