Grease
/ Grease #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I ran out of the Kubota grease that came with my tractor what type should I use and where do I get more? The manual says Multipurpose type?
/ Grease #2
I use Valvoline #W633 Moly-fortified ....Multipurpose grease for Ford..Lincoln..Mercury...because the same grease is used in my Ford truck and and Crown Vic. Thus only one grease gun and one grease type is stocked in my garage. I think it meets Kubota specs.
/ Grease #3
I use the red premium truck and tractor grease from TSC. Between my farming and my business I use a lot and just buy it by the case. Have been using it for years with good results.
/ Grease #4
I load my two grease guns from a 5 gal. bulk bucket of molly grease, much easer than trying to load a cartridge and less expensive in the long run.
/ Grease #5
My Kubota dealer is also a New Holland dealer. They recommend New Holland Ambra grease for the Kubota and everything else. I have been using Ambra for three years on my tractor and all my attachments. I think greasing at the proper intervals is more important than the type of grease used as long as it is good quality grease. I figure New Holland should know how to make good grease to use on farm equipment.
/ Grease #6
I've seen the Kubota grease tubes at the dealer-moly-disulphide grease,the black stuff.I also use the Valvoline 633.Been using moly for over 30 years with excellent results.
/ Grease #7
So. The cheapest multipurpose grease from the box store is not adequate? What is the difference? I certainly over grease my tractor but I might be using something that is no good. (???)
/ Grease #8
I just use slippery grease on everything except my high speed U joints and I have a separate gun with redline synthetic (I think) for them.
Like others, I pay more attention to when I grease it then the type of grease I use.
Bobcat SC72 (A64127)
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A65563)
2022 Ram 3500...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
12x20 Car Port (A65640)
12x20 Car Port...
