Greasing a King Kutter Tiller
   / Greasing a King Kutter Tiller #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
The grease zerk on the opposite side of the gear drive gives me concern. I can pump grease into it....say 10 stroke or so.....and I don't find any grease coming out anywhere. (I realize 10 strokes is too much - but it doesnt come out anywhere.) Then after waiting a few minutes the....zerk lets much of the grease back out of the "reservoir" (bearing) I just filled.
It's done this since new. Anyone have the solution here?
   / Greasing a King Kutter Tiller #2
Then it is probably greased and you have a really tight seal against the shaft so nothing escapes the bearing and what you are doing is just pressurizing it.
   / Greasing a King Kutter Tiller #3
Mine took over 50 to get the grease to show I was determined to either pop the seal or see grease, didn't pop!
   / Greasing a King Kutter Tiller #4
Mine has been doing the same. Doesn't seem to affect performance. I've had mine for about 3 years. I think charleyfarmall has the right idea. I still give it a few squirts every 10 hours of use.
Thanks for the responses. I had come to a similar conclusion earlier....but figured I should ask. A few grease pumps it is! :thumbsup:
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A55788)
2013 Mitsubishi...
1983 Case 580D (A47477)
1983 Case 580D...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
