AKKAMAAN
Veteran Member
Well replaced the cracked cover and started up the tractor and no leaks! Thought that I was in the clear. Not my luck, put it all back together and now the spooler valve are frozen! Will not move. I disconnected the back hoe from the tractor and still will not move. I cracked a couple of line thinking excess pressure but nothing doing. Going nuts. Any idea what may be causing this? None of the 6 valves will move even when the tractor is not running and disconnected.
thanks
I posted on the picture on post#14,
that the bolt require torque wrench and manufacturer advice on torque. Also manufacturers recommendation on the O-rings between the sections....
This is exactly what happens when these get tightened improperly....:thumbdown:
Did you get these torque numbers???
The key is to tighten these bolts so the O-ring get compressed , but not the valve sections....depending on number of sections (length of bolts), torque is different...
