Great Bend Loader
/ Great Bend Loader #1
bar197
Western Kentucky
Hello everyone,
I recently acquired a Great Bend 220 Loader that is slightly used. I have a 2000 model JD 4200 tractor that I want to put it on. My question is this, I obviosly do not have the mounting brackets for the tractor for this loader. I do however have the resources/skill to build them, but I dont exactly know where to start. I have rigged the loader into place where I think it should set, but I am not sure. What position should I place the loader in to get my measurements for the brackets? In other words, should the cylinders be all the way retracted, partially, or what? BTW I contacted Great Bend in reguards to mounting brackets for my tractor and got nowhere. Any and all info/suggestions are greatly appreciated.
Thanks in advance
Brad
/ Great Bend Loader #2
I would personaly drive the tractor on 2x6 or 8 scraps to lift the tires 1 1/2" off the ground and the loader bucket flat on the floor, this should give you a 1 1/2" dig depth with a level bucket. Its too bad GB was no help, I have had two of there 260 loaders and loved them. If I had a choice I would still have one. I know there is some around, surely some one could give you a few measurements for a jump start. Good luck
DDT
/ Great Bend Loader #3
Hello everyone,
Thanks in advance
Brad
GB is part of Bush Hog. They are not in the best of times. A good BH dealer may be able to help you.
Poly Machine & Parts (A64047)
Poly Machine &...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
1991 PROLITE GOOSENECK HORSE TRAILER (A62130)
1991 PROLITE...
APPROX (9)PIECES OF 2'X11' CORRUGATED METAL SHEETS (A62131)
APPROX (9)PIECES...
2013 KBH Hopper Bottom Trailer (A64047)
2013 KBH Hopper...
2016 JOHN DEERE 310L BACKHOE (A62129)
2016 JOHN DEERE...
