Grinding when putting in gear
   / Grinding when putting in gear #11
I was shifting it without it moving at all. How do you adjust the clutch on these thing?
Did you let out on the clutch in between shifting? If so that will get the tranny gears moving again. This is normal on non-synchronized transmissions, moving or not.
I have not tried that, but I will thanks.
   / Grinding when putting in gear #13
Call Valley Power on their 800 number 800-609-5110. They know these backwards and forwards.
   / Grinding when putting in gear #14
That will only help it grind more. If you push in on the clutch and wait a few seconds, giving the spinning gears time to stop, there should be no grinding. If it still grinds, the clutch needs adjustment or was installed wrong. I would also recommend Valley Power.
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
2021 BOBCAT T870 SKID STEER (A52705)
2021 BOBCAT T870...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
NEW 24ft Feed Bunk Wagon (A55218)
NEW 24ft Feed Bunk...
