Gripping well point to pull using 3-point lift
   / Gripping well point to pull using 3-point lift #1
MNBobcat
Platinum Member
I've been told that the 3-point lift on the back of a tractor works great for pulling shallow well points. What is the trick to gripping the pipe? Will a chain wrapped around the shaft of the pipe tighten as its pulled or will it just slip?
I'll be doing this at 6:00am tomorrow. Just looking for ideas on how to grip that pipe.
   / Gripping well point to pull using 3-point lift #2
A chain and a slip hook will grip a pipe well. Wrap several turns of chain around the pipe with the hook on the lower turns. Then place the hook on the last / highest loop. Otherwise the chain will spin the pipe. Useful, if spinning the pipe is what you want.
   / Gripping well point to pull using 3-point lift #3
Put an elbow or a Tee on the top to lift the first section. Then lift at the couplings by wraping with a chain. I used the loader to lift my pipe and didnt have too much problem....not sure with limited lift of the 3 point linkage.
I ended up using the skidsteer. Didn't seem to matter how I wrapped the chain. It gripped. Took less than 5 minutes to pull the point!
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
2014 Toro Groundsmaster 4500D Commercial Rotary Mower (A56857)
2014 Toro...
2006 CHEVROLET EXPRESS SERVICE VAN (A58017)
2006 CHEVROLET...
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2014 DRAGON 130...
DEUTZ MARATHON...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A56435)
BOSS 990 Fuel...
