geneP
Platinum Member
- Joined
- Jun 28, 2000
- Messages
- 833
- Location
- Central Mississippi, USA
- Tractor
- Case-International 385, Kubota L5450 w/LA1150A loader
Engagement should be reasonably direct, but not so fast that it jerks the machine (or operator) around. The important idea for clutch life is not to ride the pedal. Don't slip the clutch as a means of speed control. That kills any clutch - wet or dry.
Our L3 shuttles have adjustable engagement speed to correct for climate (oil viscosity) But it's more for operator comfort. Any setting will be ok for clutch life. Your Mississippi summer shifts will be softer using the #3 orifice where my Mass winter shifts would be better on #1.
Just to be sure we are talking about the same positions. My manual says "#1 is for normal working conditions and has the top of the adjusting lever pointing toward the outside (or to the left) of the tractor. If the shuttle shift engagement seems too slow, use #2 (adjuster pointing straight up and down). When operating in outside temperatures below 0 degrees F, use position #3" (top of adjusting lever pointing toward center of tractor). So, for warmer temperatures, I guess mine is already on the most aggressive setting of #2 (vertical position)?
