GUMBALL TREES!
/ GUMBALL TREES! #1
quarkion
NC
Kioti CK25 gear
I need help! I have these small gumball trees on my land. Ive cleared everything else off but these small stubs are still sticking up out of the ground about 5''. I need advice on getting rid of these stupid things. Ive rented a 90 hp bobcat on tracks w/ toothbar and it just stripped them. Ive also bushhogged them and thats why I have only 5" out of the ground. Can I spray them or something? Help me please Im building a home and barn there right now. The roots on these things are about 2 or 3 feet in the ground and I have hundreds of them so I cant dig that deep into the ground to get them out. Thanks!
/ GUMBALL TREES!
/ GUMBALL TREES! #3
Sounds like you should have rented a backhoe. /forums/images/graemlins/wink.gif The other thing I've seen people do is dig part way down, then cut them off below the surface with an axe or chainsaw. Of course you'd like to keep any dirt out of your chainsaw, if possible.
/ GUMBALL TREES! #4
/ GUMBALL TREES! #5
Ask your Bobcat rental store if he has one of these? They call these tree and root bucket and would be perfect for what your doing.
I made this one and it works great!
Jim /forums/images/graemlins/smile.gif
/ GUMBALL TREES! #6
/ GUMBALL TREES!
yea I like that idea! do you think I can get one for a Tractor Bucket?
/ GUMBALL TREES!
/ GUMBALL TREES! #9
I don't see why not? I made mine fit a Bobcat universal mount, It would depend how your bucket would attach to your tractor. I am sure you could do a search and come up with some good results. Here is back side
I made this from 3/8 plate and reinforced all over and I added hoops for lifting and strapping trees to bucket for transplanting, Its nothing more than a huge shovel 4 feet long and 14 inches wide
/ GUMBALL TREES! #10
/ GUMBALL TREES! #13
What's a gumball tree? a Sweet Gum?
Also, can you fill out your profile so we know where you are?
/ GUMBALL TREES! #14
/ GUMBALL TREES! #15
If these are sweetgums you are talking about, you will need to treat these to keep from resprouting - maybe more than once, as they are very tenacious.
You may want to try lowering your cutter and cutting perpendicular to the original cut - this might help take some of the remaining stalks out and would more than likely splinter the rest - You will still have stobs to deal with.
If you are looking for immediate clean results a dozer may be your best bet, but more than likely you will still have resprouting unless you first treat existing stalks with herbicide.
/ GUMBALL TREES! #16
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
24in pin on tooth excavator bucket (A61306)
24in pin on tooth...
John Deere 3025E (A53317)
John Deere 3025E...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
Year: 2018 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A59231)
Year: 2018 Make...
