Gun and ammo question
   / Gun and ammo question #11
The advanced development of sabot slug rounds add reach and make shotguns extremely accurate with a single projectile...
   / Gun and ammo question #12
You can fire 22 lr, 223 and 5.56 all in the same gun safely, I do it all the time.
Buy a Rock River Arms coyote model that has the Wylde chamber works great for both .223 and 5.56 and buy a 22 LR conversion bolt and magazines like this. Great way to practice.
Agreed.. to do the 22lr, he'd need a conversion bolt / chamber.
410 will fire in guns with long chambers made to fire 45lc and 410 handgun or otherwise. things like the judge, circuit judge, etc..
a 556 chamber will take 223 fine. 556 IN a 223 and you may find pressure issues due to the chamber lead
   / Gun and ammo question #14
Buy a 5.56 for things going south. Buy the 22lr for varmint. AR 556 around $500 10/22 around $200 You can get a Mossberg® 702 Plinkster 22LR for $160 Savage® Arms AXIS 223 on sale for $229 (non 5.56 ) both for under $400
   / Gun and ammo question #15
Interesting BUT.....you could buy a nice 22LR for what this conversion kit cost.
   / Gun and ammo question #16
Yes BUT that wasn’t what the original poster was inquiring about. He wanted to fire 22LR/.223/5.56 in the same rifle and a few said it couldn’t be done. It can.
It’s not the .22 I grab when dispatching a varmit on the farm, but it’s a great way for low-cost live fire practice and familiarity with an AR based rifle. You need numerous 22 rifles!
   / Gun and ammo question #17
FWIW, a lot of 'stuff' on the interweb about the interchangeability of .223 and 5.56 NATO.
a trusted source -American Rifleman | .223 Remington Vs. 5.56: What's in a Name?
Yes they are the same diameter but as mentioned the pressure is different. NEVER fire 5.56 in a 223 Rem. not rated for it. A lot of newer firearms will shoot both but there are guns out there not designed for the pressure of the 5.56. (Max - approx. 55000 psi for a .223 rem, max - approx 62,000 for 5.56 Nato (and it has to proof to 125% for full cert. I believe. Also the throat guidelines are slightly different thus allowing the bullet of the 5.5.6 to engage sooner in a .233 rem thus possibly increasing the pressure even more)
Also a .22LR is actually a slightly different bore diameter than a .223 Rem. Yes you can do it but you need to change out some parts. You can't just grab a .22lr and stick it in your 223 Rem and expect it to work. Heck you can shoot .22lr in a .45, if you don't mind changing out a few parts.....
   / Gun and ammo question #19
Why not get an AR15 5.6mm/223 for everything? Put an inexpensive red dot sight on it - the ammo isn't all that expensive. You could later buy a 6.5mm Grendel upper and transform it into a dandy deer rifle.
   / Gun and ammo question #20
20 Ga Youth, pump or semi-auto. If slugs and buckshot cost too much, ... how many rounds/yr are you going to shoot???? Whatever you consider, there will something better. Who ya gotta please? It's not like a car, and you only have to buy once.
Why I recommend:
- Short o'all length eases handling indoors for home/personal defense.
- Many wives won't shy from 20 Ga recoil. 'More power' doesn't help if the Mrs cringes and misses.
- Plenty of power for deer to 100 yd (ballistically similar to .45-70, and .50 cal muzzleloader, ie: projectile weight 300-400g, diameter ~.5", velocity 1200-1400fps)
- Measuring your manhood (too much oomph) for 'the guys' won't help Mama's cannon-confidence during a break-in when macho man isn't home. :rolleyes:
Deer/HD loads: 2� Gauge Ammo - 2� Ga. Shells for Sale
Raccoon/HD loads: 2� Gauge Ammo - 2� Ga. Shells for Sale
I prefer Remington and Win ammo as linked above. No problems grouping/patterning in my Rem 11-48 (licensed, round-top Auto-5) .. despite having a 'poly-choke' which isn't 'all that' to have.
Any of us might add an -er to another's suggestion. Don't compromise usability for cheap or to do several things poorly vs doing one well and having a gun for each purpose. 2 usually covers uses mentioned by our OP, if he gets the right two, and the Mrs should approve or .. ??
44029 (A51692)
44029 (A51692)
2007 INTERNATIONAL 4300 SBA 4X2 DUMP TRUCK (A51406)
2007 INTERNATIONAL...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
