GX345 FD611V Engine is toast
   / GX345 FD611V Engine is toast #1
kingofbytes
Hello!
I wanted to pick everyone's brain (if I may) for any advice, tricks, tips, places to purchase engines or parts or both, etc.
I had a mouse climb up into the engine and start chewing on things all within a week. I did NOT know this happened.
Then, within my second to last row of grass cutting, the engine starting to make ungodly noises. I immediately stopped the engine and checked for what was up. I saw oil all over my mowing deck (directly under the chassis...not visible while mowing). I thought I sprung a leak. Anyway, I think I fixed the issue. Now the engine won't even crank.
Dealer says it's toast. I don't mind trying to repair. If you have any guidance, it would be appreciated.
Looking in at the cylinders through the spark plug hole, it appears to have a nice black , textured glaze on them. Any thoughts?
   / GX345 FD611V Engine is toast #2
Hello!
Dealer says it's toast. ... Any thoughts?
What exactly is the dealer saying is wrong.
Crank main and rod bearings galded and bearings spun?
Valve train and cam ruined?
Piston and rings damaged?
Cylinder walls scarred?
There are many things that could be "toast" some combinations are not practical to repair. Sometimes it makes more $ense to replace the engine... even with a good used engine. KennyV
Hello!
The dealer wasn't specific. I emailed them with my problems and they stated it would probably be more costly to repair than to replace. They stated the F611V's aren't made anymore and but that they can source all the components.
The estimate was about $2800 for the engine (purchased in components, not the whole block) and estimated 11 hrs ($70/hr) for labor. That did NOT include any other issues which may be found. They were honest enough to note that the Deere book shows 5-6 hrs for labor but only if they can buy the complete core. And also, they said they'd be doing some cleaning, etc.
I saw the site you linked and was wondering about them. Does the engine actually just simply install? I'm ok with regards to being mechanically inclined, but am no expert and know my limitations.
I've also looked at used 345's and they want 4-5K for them. With all the 0% financing available, I'd think I'd just upgrade instead of forking over 4-5K for a repair. Let me know experiences or concerns with these Briggs Vertical kits. Thanks!
   / GX345 FD611V Engine is toast #5
There is nothing very special or unique about vertical shaft gas engines... If I were you I would take them up on their "E-mail us about your John Deere GX345..." I am sure they have covered about any problem anyone has had. It sounds like they are 'the pros from Dover' on this particular swap.
$1050.-- for a complete new engine is a bargan, plus at only 125 pounds it will be very simple to R&R looks like the only modification will be adding the choke cable that they provide and tell you how to install.KennyV
   / GX345 FD611V Engine is toast #6
northern lists a 21hp B&S for $620....
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200354783_200354783
course put a nice 20hp honda in it and your looking at $1400
   / GX345 FD611V Engine is toast #7
If it were mine, and I decided not to upgrade the whole mower, I would not replace it with another B&S. I have 6 B&S small engines (up to an 18hp Vanguard IC) and 1 Kohler, 1 Kawasaki and 1 generac. All 6 of the B&S engines have been a constant pain. Yet I have had absolutely no problems with the other 3. I have had the Kohler since the mid 80s.
   / GX345 FD611V Engine is toast #8
I sure wouldn't want to replace a LC Kawasaki with a B&S Intek. I'd hunt for a good used engine, and if I couldn't find one then I'd see about getting one of those Kawasaki LC replacement engines or check my options to replace it with a Honda GX V-twin.
Can anyone tell me the procedure to "hand crank" (without using electric start) the engine on the GX345? I can't find information on how to do that anywhere.
I am trying the seizedengine.com product and need to "hand crank" either by hand or using an air gun.
Thanks!
   / GX345 FD611V Engine is toast #10
Save some $, save some time and a LOT of aggravation. DON'T use the seizedengine.com product...
The problem you are having is from little or no oil... you have galled surfaces with metal transfered from one surface to the other.
Take the pan off and look at a bearing! look up into a cylinder and you will most likely see lots of scratches gouges... remember the "engine starting to make ungodly noises" comment you made in the first post. Look in the bottom of the pan you will see metal filings and shavings maybe even chunks...
seizedengine.com product is intended to unseize an engine that has rusted corroded during storage or long periods of non use. (BTW Hoppies#9 will do that job).
Also never use an impact wrench, air or electric to turn over any multi-cylinder engine. I find it hard to believe they are recommending that...
KennyV
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2003 Big Tex 10PI...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
