Gyro Trac GT 25 Review
/ Gyro Trac GT 25 Review #1
fishfactor
Monroe, NC
(2) 2014 CAT 299DXHP / FECON
OK, we've had the GT 25 for a little while now so I figured I would post my thoughts. When we were considering making the purchase I couldn't find any reviews, so maybe this will help someone. I have been operating a Bobcat T320 with a fecon mulcher for about 3 1/2 years. The GT 25 is a 2005 with just over 2000 hours.
The GT 25 mulches great. On small stuff (4" and under) you can put it in low gear (ours is a 3 speed) and go almost full speed about 2" off the ground as long as it's not all 4" and not extremely thick. Then drop down and back drag leaving a very nice, fine mulch, finished product. It would take 4 or more passes with the hammer head to get anywhere close to the quality. Larger trees are no problem especially with sharp teeth. The largest I have cut is a 20" white oak which took just under 10 minutes.
The cab: Nice and quiet. It has been wet so I can't speak for the dust situation. Plenty of room, although no cup holder but I plan on fixing that. The cab is pressurized so I would assume that dust won't be a problem. If you just barely open the door the engine is very loud so things seem to be sealed well.
Fuel consumption seems very good, but I only ran one test. Our transfer tank has no meter and we use it for our Bobcat as well. To get an idea I filled the GT 25 and ran it for 8 hours on a logging cleanup job. Then filled it at the gas station with 55 gallons. This comes to 6.875 gallons/hour. We ran 2250 RPM which isn't WOT. I have never been a fan of wide open.
Manueverability is a little lacking, especially compared to a CTL. Turns need to be 3 point it most situations. You can spin 360 degrees on flat ground, but how often are you on flat ground?
Maintenance is normal so far. If you sharpen the teeth daily I can do it in about 30 minutes. I don't try to achieve a razor sharp edge because it would only last a few minutes anyway. The engine compartment is spacious and everything is easy to get to, except that hydraulic filter under the cab in the bottom corner. You have to stand on your head to change it.
The undercarriage gives a much better ride than the CTL, and if I ever get around to fixing the air in the air ride seat it will be even better. I think the little 12V compressor is dead, just haven't taken the time to check on it.
The unit really needs a hydraulic push bar which I may add. Smaller (6") trees are constantly falling over the top of the push bar and then spinning to lay sideways between the cab and the push bar, on top of the hoses. Stopping to move them is a pain. Leave them and you may spring a leak. Maybe it's the operator (me) but a hydraulic push bar would solve it for me.
So far two concerns which could become big negatives: tracks and teeth.
The tracks are original and have 2000 hours on them. A few of the crosslinks were broken when we got it and we brushed it off as no big deal. They were fine on flat ground. This week we were on steep, bad terrain. No rocks, just steep and gully's. The few broken crosslinks grew. I'm hoping it was a chain reaction from a broken one putting more stress on the next one causing it to break and so on. I ended up changing 12 of them all on one side. That seemed strange to me. I also may have had that track too tight. If this is a result of tired tracks I'll be OK once we decide to drop $9k on a new set. If this is normal this is a BIG negative.
We have had problems with the teeth staying tight. I installed a new set including bolts, nuts, and those funny lock washers (nord I think)and used a 600ft/lbs impact wrench and blue loctite. After the first 8 hours several were loose. I have since started checking them each day while sharpening using a 1/2" ratchet and a 3ft cheater bar putting all I can on it. I usually find 1 or 2 a little loose. I have not put loctite on them since the first time which may help. Teeth that get loose quickly break off the lip on each side that holds them straight which results in wear to the mount base. If you don't catch it soon, you will be welding and grinding to rebuild your base.
Overall I am happy with the purchase decision pending the track situation. We bought this machine used and you never know what a used piece of equipment has been through. For the price we paid, the performance per dollar is very high. If we had paid the new price of $350K feelings may be a little different. Flat ground 4" and under you can mulch an acre with a nice finish in 1 1/2 - 2 hours. The combination of the Gyro Trac and T320 is nice. The bobcat makes a great chase mulcher for the tight spots and the stray limbs, etc that fall to the side. It would be difficult to do most jobs completely with the Gyro Trac simply for this fact. Some ditches and gullys you just can't get into with a large machine.
I will add any future findings as they occur, good or bad.
/ Gyro Trac GT 25 Review #2
Hey fishfactor,thanks for the good information.
Last week I saw a gt25 on a 10 ton gooseneck pulled by a 1 ton dually! Crazy.
Meanwhile, I'm halfway through mulching 60 acres of FL jungle,only one hyd hose broke at the fitting so far.
Merry Christmas!
Go to Lowe's/Home Depot and get a piece of corrugated drain pipe. Cut it to length and slide it over your 3 hydraulic lines and the electrical line. It will save you hundreds. **Tip came from member Dirtroad.
/ Gyro Trac GT 25 Review #4
I think your bolts coming loose is due to the bolts need changing. With 600 ft lbs they stretch. try a few bolts and see if this helps. Also I can help with the blades as well. we have several different blades, the one's equal to Gyrotrac are our lowest grade. Let me know. I'm glad your machine is working good for you.
Robbie - I put new bolts in with the new teeth. It seems to be getting better. When we get a break I am going to put loctite back on all of the bolts and see if that works. PM me the info on your blades. I've got one extra full set now but would like to know all of my options.
Thanks for getting me in touch with Justin from Soft Track. I made my first purchase with him this week. He was great. We had a tractor trailer delivering about 15 miles away from them (we have a trucking company as well). Justin took the parts to him so he wouldn't have to spend a lot of time picking them up.
/ Gyro Trac GT 25 Review #6
Fish the undercarriage is a common issue on them, they do cut well when used above ground (Obviously). Check the trueness of the tool holder, i have one on my 180 that is slightly, very slightly tweaked and it will loosen all the time. No amount of bolts, locktite, etc will keep it tight. To totally fix the problem the only way to fix it is to change the holder, if thats the case. I don't know if the gyro teeth have the same design as the Cimaf but maybe try Robbies teeth, thats the only teeth I have ever tried.
/ Gyro Trac GT 25 Review #7
tack it on or change the holder once you get play in a tooth they wont stay tight
Update: Resolved the teeth coming loose. Turns out my new IR Impact is not performing. It is rated at 600 ft lbs, yet I can still tighten bolts a little after using it with a 1/2" ratchet. No problems now with the teeth coming loose. Tracks are still to be determined. Why don't they offer this machine with a steel track undercarriage?
/ Gyro Trac GT 25 Review #9
I have a sub contractor that works for me on large jobs with a gt25. He can mulch a 20" oak completely in about 4 minutes, maybe 5 tops. Pine tress the same size in half the time. Huge pecan trees 5 mins each!
UPDATE: As mentioned earlier, I resolved the loose teeth problems. I also resolved the track problems a few weeks ago.
First, 50% of the crosslink bolts were loose on the side we were having problems with. Our trailer also had angle iron on the ramps and dovetail. The spacing was just so that the crosslinks would catch on the angle and bind when loading/unloading. We put new ramps and dovetail both with oak inserts on. The track slack adjuster was also leaking down due to a improper repair sometime in the past. After replacing the slack adjuster, ramps, dove tail, and a ton of bolts, so far the tracks are doing much better.
I would still like to see a steel undercarriage on there and may look at a conversion down the road. But for now, the crosslink undercarriage is sufficient.
4 years later, what are your thoughts?
It took us a while to find all the problems, but after we spent 30K fixing stuff that had been neglected or improperly repaired by the past owner, the machine did great for us. New tracks, new drive axles, pulled the pumps and gear box and replaced all seals, new tensioners, new sprockets, all new hoses, .... it just seemed like it would never end. We finally got it right about the time we finished up the contract we had it for. We put it for sale last fall and some guys in TX got a nice machine.
It was a good machine, but we found we could do most of our work with CTL's. So now we use 2 299DXHP's 99% of the time and rent bigger mulchers if we need to.
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
10' CONTAINER (A60432)
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2007 FREIGHTLINER...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2021 Polaris Ranger 570 EFI AWD Gas Utility Cart (A59228)
2021 Polaris...
2004 TAKEUCHI TL140 SKID STEER (A60429)
2004 TAKEUCHI...
