Hairline crack in weld on Hydraulic reservoir PT 425
   / Hairline crack in weld on Hydraulic reservoir PT 425 #11
Pulled the lid off today. No gasket under the lid, must have deteriorated. Cleaned all the surfaces, very clean. Used Pro Seal RTV silicone gasket maker (red) for high temperatures. Also replaced all the bolts and washers with stainless steel ones. Looks good, so far!
Thanks guys.
   / Hairline crack in weld on Hydraulic reservoir PT 425 #12
Great news. The red was unnecessary (but I would have made that choice as well). Your oil tank doesn't get that hot if you can believe it, although my legs could say something otherwise.
   / Hairline crack in weld on Hydraulic reservoir PT 425 #13
cherylspt
mine was cracked in the same spot. Had my friend weld it up and works just fine
   / Hairline crack in weld on Hydraulic reservoir PT 425 #14
Late to the party, but ever since I bought it, my 425 has had a tiny oozing leak at one of the hydraulic tank seam welds. It's just enough for a film of oil to spread and attract dust. It's annoying, but not enough to drain the tank, clean clean clean and then clean some more so I can seal it up. I just give it a bath every few months whether it needs it or not.
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
HARDEE D-3-816 LOT IDENTIFIER 142 (A53084)
HARDEE D-3-816 LOT...
