Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer?
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #11
I installed the rotary into a 55 gal drum and after I pumped out about two gallons it quit. But I never vented it. Do I need to punch a hole in that plastic cap?
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #12
Doesn't the barrel have two screwed in caps or plugs; two different sizes? My pump screwed into the larger one and I always loosened the smaller one for a vent when I pumped fuel out.
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #13
same on mine.
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #14
I'll be back up there on Friday so I'll check it out. Thanks.
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #15
So now it works! The smaller hole had a sealed plastic cap on it and I thought I needed to puncture it, but underneath is a piece that unscrews. After unscrewing it, I pumped out 15 gallons with no problem. Except my arm was tired by then. :)
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
CAT Skid Steer (A50322)
CAT Skid Steer...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2017 Ford F-750 Altec LR758 58FT Insulated Bucket Truck (A52377)
2017 Ford F-750...
