Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer?
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #11
I installed the rotary into a 55 gal drum and after I pumped out about two gallons it quit. But I never vented it. Do I need to punch a hole in that plastic cap?
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #12
Doesn't the barrel have two screwed in caps or plugs; two different sizes? My pump screwed into the larger one and I always loosened the smaller one for a vent when I pumped fuel out.
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #13
same on mine.
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #14
I'll be back up there on Friday so I'll check it out. Thanks.
   / Hand pump (for diesel )(Rotary / diahpram or Lever / piston) which do you prefer? #15
So now it works! The smaller hole had a sealed plastic cap on it and I thought I needed to puncture it, but underneath is a piece that unscrews. After unscrewing it, I pumped out 15 gallons with no problem. Except my arm was tired by then. :)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
