Hand surgery
/ Hand surgery #21
Must be something new - when I had mine it was hand/wrist above the heart. Couple pillows on the arm of the recliner did the job back then. Ask the Dr what he suggests. Maybe there is some kind of strap device.
/ Hand surgery #22
Left hand carpal surgery around 2008. Done as a hospital outpatient with general anesthesia per the doctor. Doc did recommend not doing both hands at the same time, otherwise the wife would not be a happy camper with some of the 'maintenance' in taking care of me. The doc did have a peculiar sense of humor. In the last year or so my right hand has been acting up with carpal symptoms and occasional trigger finger problems, but not bad enough yet I'm going to do anything about it.
Has anyone had physical therapy/exercise prescribed following carpal surgery? My own doc didn't suggest it, but I've heard a few people had done it.
/ Hand surgery #23
Nope, doctor didn't mention it (thankfully). When I had mine done, they were done at the same "day surgery" clinic, but with different anesthesiologists. The first one did some kind of "block" (can't remember exactly what he called, but I was not asleep; just listened as he and the surgeon talked). The second one put me entirely to sleep.
/ Hand surgery
Thanks much Oosik you have been very helpful.
/ Hand surgery #25
I have had both of my hands done many years ago. Recovery was fast, with very little discomfort. Was not able to do things such as wielding a screwdriver that applied pressure to the incision area for a year or so. The worst discomfort associated with the surgery was the nerve conductivity test done to determine if I needed the procedure, that was a bit brutal.
Each of my procedures was done by a different surgeon, but they both advised me to take it easy for a few days then to use my hand as much as possible as long as it was not too painful.
All things considered I found this to be an easy procedure to recover from and I got a lot of relief from it. I was actually looking forward to the second procedure because I knew how much better I would feel afterwards.
Like Ossik said, a couple of pillows to keep it elevated above your heart for a day or two until the swelling goes down. Wiggling your fingers as much as you can will also help to reduce the swelling.
Good luck with this, I'm sure that you will do fine.
/ Hand surgery #26
Mapper and MarkF48 did you have open or endoscopic surgeries?
/ Hand surgery #28
Open on both, the first one done about 1982 has a scar that starts an inch or so up my wrist and ends in th center of my palm. The later one about 1990, the scar starts at the heel of my palm to the center. Both were successful and recovery was similar.
Summer of 1979 I broke my arm shattering the end of the radius just behind the joint plate which was broken in two as well. The same orthopedic surgeon fixed the break and did the CT surgery. He felt that the fractured wrist contributed to the carpal tunnel problem " like I set a bomb off in the joint" according to him. Of course my job at that time was drawing contour maps so that may have also contributed as well.
/ Hand surgery #29
thanks, glad it all worked out well for you guys,
Murph keep us up to date on your recovery next month, i'm sure you'll
heal fast and be glad it is all over so you can move forward :)
/ Hand surgery
Will do
/ Hand surgery #31
Murph good luck later this week
i had my first hand (R) last thursday, in and out of the day surgery center in 90 minutes,
what a well oiled machine they have going on there!
felt good enough to go back to work Friday, and over the weekend really had no issues,
even helped get the tree up and some outside lights put up while the weather was good.
don't want to hijack Murph's thread, but the CTL part of your procedure seems pretty
mild, not sure what your are facing with the other issues they are fixing..
good luck
/ Hand surgery #32
Thanks everyone for the advice and get wells. Surgery is on 12-8. December will be interesting for sure.
Good luck Murph. May your recovery be swift and the results 100%
/ Hand surgery #33
3 days away, good luck.
/ Hand surgery #34
Had both hands done at the same time back in 2012, I only wanted to be put under one time, both of my palms were sore for about a year but the numbness and pain were gone, still no trouble today, I wish I hadn't waited so long to get it done. Good luck with your surgery. Charlie.
/ Hand surgery
Surgery went well but my arm is like its gone, They gave me a nerve block before the operation. have to keep arm elevated so i'm glad I bought a coat stand. Having to do everything left handed is very hard. See doc on Tuesday. More later.
/ Hand surgery #36
Sounds like "So Far, So Good".
Cheers,
Mike
/ Hand surgery
/ Hand surgery #38
Glad to hear all went well. Thanks for the rapid follow-up. Lots & lots monitoring this site.
/ Hand surgery #39
Murph,
Glad to hear it went well ... heal up quick !
832744 (A61166)
832744 (A61166)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Welcome to the Farm Metal Decorative Sign (A61569)
Welcome to the...
2020 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2020 Globe Trailer...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
