Harbor Freight 3-point quick hitch
   / Harbor Freight 3-point quick hitch #31
2vga and 1vga come up the same for me, 69.00.
   / Harbor Freight 3-point quick hitch #32
Reg, The lift arms of the tractor are supposed to fit into a slot on each side of the quick hitch and be pinned in place. The tractor lift arms will not fit into the slots in the hitch that they are supposed to fit into. In order to allow the item to fit, the slots (opposite each bottom hook of the quick hitch) will have to be widened about 1/8". This can be done by cutting the metal plate forming one side of each slot and moving that piece of plate outward at least 1/8 and welding it into the new position. Correct registration must be preserved so that the holes in each of the plates forming the slot remain aligned so that the pin will fit thru. Either this mod, or grind down the width of the thru hole in the tractor lift arm balls! That would compromise your tractor.
Larry /forums/images/graemlins/tongue.gif
   / Harbor Freight 3-point quick hitch #33
   / Harbor Freight 3-point quick hitch #34
Spyderlk,
Thanks, I think I understood what you wrote....
Hmmm, I'll read it again when I get the item and have it IN FRONT OF MY NOSE (-:
Maybe again when I've tried to use it for a couple of hours without success.
\R
   / Harbor Freight 3-point quick hitch #35
Spyderlk,
\R
   / Harbor Freight 3-point quick hitch #36
93691-1VGA part number search linked back to $69.99 and the part number 93691-2VGA.
   / Harbor Freight 3-point quick hitch #37
   / Harbor Freight 3-point quick hitch #38
Did any of you that ordered receive on yet? What do you think....
Exactly what is Cat 1 spacing? I am trying to see what I have it will and will not work on. I just spent 20 minutes hooking up my KK disc /forums/images/graemlins/frown.gif
   / Harbor Freight 3-point quick hitch #39
   / Harbor Freight 3-point quick hitch #40
Mine is not here yet. I will post all measurements when it arrives with pics.
Mike
UNUSED FUTURE 72" CLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 72"...
2014 Ford F-250 4x4 Ext. Cab 8ft. Flatbed Truck (A55852)
2014 Ford F-250...
Trac Vac PT Lawn Vacuum (A56469)
Trac Vac PT Lawn...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
2015 Dodge Charger Sedan (A55853)
2015 Dodge Charger...
2023 Air Chipping Hammers (A55851)
2023 Air Chipping...
