Harbor Freight 3-point quick hitch
   / Harbor Freight 3-point quick hitch #141
Is there anyone that has one of these QH that does work without major surgery?
I have seen these pictures and from what I see? Like another member posted, its a waste of time and lots of unnecessary trouble to order and wait for something that can't be used?
I can't wait to get mine that won't work /forums/images/graemlins/confused.gif
Jim
   / Harbor Freight 3-point quick hitch #142
When you have a good reason - - "Item not as advertised" is a good one!!, you can call customer service, 800-4443353, and they will send you a postage paid return lable. You can probably negotiate a 10 or 20% discount if you will keep it to fix yourself. They offered me 10% off my order (a $174 order) if I decided to keep it. I have decided to send mine back for exchange at least once in the hopes of getting one with the slots near 1-3/8" so I can just flex them rather than bend or weld them. At least 0ne poster has gotten one very close to correct. HF will try to please those with a legit complaint. "Will not fit" is as legit as it gets.
Larry
   / Harbor Freight 3-point quick hitch #143
HomeBrew, On your lift arms the balls are wider than the sockets holding them, so even something that fits tight on the balls will not prevent them from swiveling/floating in the socket toward a self aligned condition. With somethng looser on the balls (width) the balls can swivel more - all the way til the implement pin hits the socket if there is ample open space on each side of the ball. In the case of this QH implement, the slots on most are too narrow to allow the balls to enter. Widening the slots minimally so the balls will just fit gives the first situation I described. This is adequate - - no QH of any variety does much better. On the other hand, narrowing the balls to fit the too narrow slot will cause the ball and socket to be closer to the same width and the slot and ball socket will interfere more quickly preventing the ball from doing its natural swivel job.
dholly, this is what I meant in my earlier post regarding ball mod.
MrJimi, with your demonstrated abilities you will be able tofix this item to be acceptable if it is basically strong enuff for your purpose. As delivered tho,it is not likely to be a plug and play item.
Larry
   / Harbor Freight 3-point quick hitch #144
Larry, I am planning on maybe ordering another one of these, I will be welding or bolting this on to a skid steer quick attach backing plate and I seriously believe this will work great for me? I hope.
I did not go for the gloves, we have a brick and mortar HF within 6 miles of us and I have 12 pair at 6 pair for 6 dollars, I opted for the attaché case instead, item #35233 which is offered in the online coupons with the $5 off also. I think I will be happy.
Thanks
Jim /forums/images/graemlins/smile.gif
   / Harbor Freight 3-point quick hitch #145
Yes, of course, agreed, assuming you want to have full functionality of the balls when the QH is NOT mounted. I was assuming that, if I could get a QH that fit ALL my implements, I would have no prob "wasting" my ball-socket ends for the convenience. But I sure understand the reasons one might not want to do that. Hope some of youall can make those QH's working - sure is a great price.
   / Harbor Freight 3-point quick hitch #146
Did Nathan ever measure his QH slot width? If I am not mistaken, he is the only one to date that has been able to slip it on with no modification? Either his balls are beat (no offense Nathan /forums/images/graemlins/blush.gif), or his QH is 'the' exception. All others are coming with a 1-1/4" inside slot width consistently. Me thinks this goes beyond poor quality control in China, more likely someone at HF didn't do their homework...
   / Harbor Freight 3-point quick hitch #147
I agree. If all of them but one are too narrow, it sounds like a mistake in the design phase, not the fabrication phase. In other words, it sounds like they may have been incorrectly spec'd at 1-1/4". All of them have been built to spec except for the one that Nathan got (maybe he's just lucky /forums/images/graemlins/laugh.gif).
Mine hasn't shipped yet (at least my CC hasn't been billed yet). It'll be interesting to see what I get.
BR
   / Harbor Freight 3-point quick hitch #148
On mine the right side fit, but not the left. A couple of "jabs" with a very heavy pry bar widened the left side enough for it to fit. Terrible quality control, if any.
   / Harbor Freight 3-point quick hitch #149
Just got mine. Harbor Freight said it was shipped Fed Ex. Ive been waiting on the truck. And come to find out I get a call, and it came via mail. and to the wrong address on the package.
I went and picked it up. opened her up. Mine is the special one with no pins in the box.
And yes the spacing on the bottom was wrong also. The reason these are not fitting is that the bottom hooks are cast and they arent the fill width they should be. You can see where they just 'squished' the metal together to the hook thickness.
Im not sure what ill do with it now.
I hear that scrap metal prices are up...
Anyway thats my story with it. A bit disapointed at this stage. I expected the opening to have to be adjusted. But not to have to make my own pins.
Allan
   / Harbor Freight 3-point quick hitch #150
The one I got from Homier (probally the same as H.F.) didn't fit on the first try either. I just spread the quick hitch apart with a pry bar a little and presto, it's the neatest thing since sneakers.
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2020 DRAGON ESP...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2014 Volkswagen Jetta Sedan (A56859)
2014 Volkswagen...
