Harbor Freight 3-point quick hitch
   / Harbor Freight 3-point quick hitch #251
hz293 said:
I just ordered my HF Quick Hitch and they are now in stock. It will be shipped soon. However the adapter is on back order. As someone earlier mentioned, if the back order is less than $10, you have to call them to activate the shipping.
Harris
I've been on the HF web-site searching for the adapter without any luck. Could you please give me the HF number? Thanks.
   / Harbor Freight 3-point quick hitch #252
:rolleyes: :rolleyes: well, you wont find it on the website, or the search function. Its "unlisted". Or so it seems I had to go through a couple of people there before I got any type of number. here is what they gave me.
29309 HITCH ADAPTER (OPTIONAL 00/00/00 8.76
Here is the part#, description, stock date and price plus 6.99 freight
charge.
I haven't been able to get the number to bring up the part though:rolleyes:
I sent this to them
Item Description: quick hitch
Comments: I have purchased A 3 point hitch quick hitch. As with my
friends, we both found that the lower openings were "squeezed' to close
when welded to slip over the lower cat 1 lift arms. He was able to
'spread' the bottom to fit. But now finds that he and most likely
myself need an adapter to make the units work with non ASAE implements.
Is this adapter available from HF? I have already requested a return
label , but if this adapter would solve my problem I wouldn't have to
return it. I think I could get my friend to make the bottom part fit.
Thanks for your time.
They replied
It has been requested to advertise the adapter so that it can be ordered at the same time but unfortunately the company has not changed it or even sent out any information saying it will change.
You can try the number, if you get it to work let all know.Ill be calling to check on my backorder next Monday.
   / Harbor Freight 3-point quick hitch #253
Hitch adapter for quick hitch 93691-2vga is "adapter #29309-0vga". Glad I could help.
Harris
   / Harbor Freight 3-point quick hitch #254
Hey 293 can you get 29309-0vga
to work on the HF website?
I cant get it to work says its discontinued.
The numbers look like what I have. but mine didnt have any of the the letters.
   / Harbor Freight 3-point quick hitch #255
Nope, it's not on the website or in a catalog. I got that from another post in this thread. Best bet is to call Harbor freight. Their number is on the home page on the left side. Scroll down to get it. Suggestion is to wait until August 4th when they say it will be in because they won't back order unless the order is over $10. Because I ordered the quick hitch also at the same time, they put it on my order but will not ship it until I call and it's in stock. So be it. I'll call around August 4th and hope they have them in. Hope I've helped. BTW, My guess is that when they have them in stock someone will post it on here.
Harris
   / Harbor Freight 3-point quick hitch #256
Well, I ordered my hitch on July 20th and was told it was on backorder. But it showed up on my doorstep today (the 26th)? Have no idea what I'm going to do with it yet. Maybe use the frame for a project I've been postponing? Looks pretty good though...I'm impressed so far.
   / Harbor Freight 3-point quick hitch #257
The adapter can be ordered online by selecting the option to order from the catalog (on the column on the left side of the window) and enter the number 29309-0vga. It comes up and you can order it then.
Good luck
   / Harbor Freight 3-point quick hitch #258
My six pair of leather gloves arrived today in a big box filled with foam peanuts. Naturally I opened it in front of a fan, what with the heat and all. After the peanuts hit the fan, a leather duffle bag appeared. My wife confiscated it, and gave me a broom and dust pan. I can have the bag back when the peanuts are all off the floor, and in the trash. :p
   / Harbor Freight 3-point quick hitch #259
Believe it or not, not the HF peanuts, but some are made with edible material.
LOL so you'd get a free lunch as well. But seriously those peanuts are a real pain.I like the packaging where they put the stuff into the box, and then a layer of some foam forming packing, it "melts" to cover snuggly the items.
Glad to see your gloves arrived.
   / Harbor Freight 3-point quick hitch #260
Good luck
Thanks. It took a couple of tries, but it finally let me order the adapter.
Terry
2016 Ford Escape SE SUV (A55853)
2016 Ford Escape...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2016 KENWORTH T880 TRI AXLE DUMP TRUCK (A56138)
2016 KENWORTH T880...
2430 (A51248)
2430 (A51248)
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
