Harbor Freight 3-point quick hitch
   / Harbor Freight 3-point quick hitch #321
I just picked up one from the HF Store and found that the unit is not fitted as well as the expensive JD I-match, but for the difference in price, who cares. It fit my JD 2305 lift arms with no problems. I did notice that the lower lynch pins that came with the quick hitch were too small in diameter. I fear that these will wallow out the lift arm balls, so I used a large rattail file to enlarge the holes in the HF Quick Hitch to accept my 7/8" link pins. It required only minor filing to get it to fit.
My next concern is the difference in the lift hooks on the HF Quick Hitch versus the JD I-Match. The I-Match upper hook is sized to 1 1/4 inch bushing and 1 1/2 inch lower bushings. This is not the case on the HF model. The upper hook is sized for the same 1 1/4 inch bushing but the bottom hooks are set for 1 inch bushings. This poses a problem as my lower link pins are 7/8 inch. I can't find a bushing with a 7/8 inch inside dia. and a 1 inch outside dia., also afraid that this bushing would not last long being so thin. Currently I am not using a bushing on the bottom hooks, just picking up right off the 7/8 inch link pins. Could this cause a problem because of the difference of 1/8 inch in link pins to hook slot?
I also had to spread apart the upper bout of my Frontier box blade by using a 3 1/2 inch long bushing instead of the 2 inch bushing as it would bind up on the bolts that attached the HF upper hook to the housing. With the top ears spread further apart the bolts of the upper hook clear the box blade without hitting. All in all it took about 5 hours to get all my implements to fit to the HF Quick hitch. I was hoping that the HF would have the same size lower hooks so that the JD bushing kit would work. Just expecting too much I guess.
   / Harbor Freight 3-point quick hitch #322
   / Harbor Freight 3-point quick hitch #323
I looked at the display model at my local store. Can't build one for 70.00. The only thing missing is a grab hook for chain and a square tube hitch receiver which will be added courtesy of my Miller wire feed. The store got in 2 ( one of which is the display ) for the sale. I think they are gathering up numbers for a huge order from the manufacturer. Many rain checks are being written up.
   / Harbor Freight 3-point quick hitch #325
I'm going to make mine adjustable to fit different width implements. Also going to modify it so it can mount on the front fel via quick attach system.
   / Harbor Freight 3-point quick hitch #326
After seeing your box blade project, I can't wait to see this! Please keep us posted.
Mike
   / Harbor Freight 3-point quick hitch #327
I also bought one from Homier. Hitch is fine. My problem is the top link. None of my equipment will work without using the adaptor. Any suggestions out there on how to modify the top link on my equipment so it will work?
   / Harbor Freight 3-point quick hitch #328
Pictures we hope, we all need some help
Jim
   / Harbor Freight 3-point quick hitch #329
I posted the following over in Parts/Repairs but I think it's also helpful here. The coupon is good for 15% off anything in a HF store, through Wednesday. They just started selling the Quick Hitch in the retail stores.
TBDonnelly said:
Harbor Freight 15% off coupon link :) .....good thru Sept. 27
HFT-USA
Don
Just a note to verify that is a good coupon, whether you are a 'Prefered Customer' or not.
I did a page-print of that (on a color printer) and it was accepted for 15% off the $70 Quick Hitch today - the most expensive thing I ever bought at Harbor Freight.
   / Harbor Freight 3-point quick hitch #330
I ordered a hitch and adapter online Monday 09-25-06. Are these still on backorder? I recived an oder confirmation but have yet to hear if it has shipped.
2016 Chevy caprice (A55788)
2016 Chevy caprice...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
20357 (A55758)
20357 (A55758)
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2014 Nissan NV200 Cargo Van (A53422)
2014 Nissan NV200...
