Harbor Freight copies StrongHand Nomad welding table...$59
   / Harbor Freight copies StrongHand Nomad welding table...$59 #21
   / Harbor Freight copies StrongHand Nomad welding table...$59 #22
Don't thank me. Our customers posted it. I just gave a link. But that table has given me an idea. I've needed a little different table to do some fab work with a jig that I built for building brush guards for tractors. I build them and sell them to dealers on the side. This may be about the right size, though its a little narrow in dimensions in depth. I need 24". It could hang over the edge though since the jig is rigid.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #23
I looked at ChuckE's video review of the Nomad. He had some problems with it and don't recommend it. He said the top bent on it just chipping slag so he reinforced the top with some square tubing.
He mentioned that it might be ok for some people who plan on only using it only for light duty work. I would think it's only intended to be used for light duty work. It couldn't be too heavily built or it would lose some of its portability.
Apparently, many would disagree with his assessment, since the Nomad seems to be pretty popular. :confused3:
I really like ChuckE's honest reviews, though. :thumbsup:
Stronghand NOMAD Welding Table Unboxing, First Impressions and Modding.. - YouTube
   / Harbor Freight copies StrongHand Nomad welding table...$59 #24
Great link for comparison, thanks. For $45 I think I'll have to pick one up assuming they have it in stock.
I haven't seen the video you refer to but I would absolutely agree this is for light duty work. It shouldn't bend with chipping slag though, that sounds like hyperbole. But, I wouldn't pound on a piece of 1/4" either. It is more for clamping a work piece in place with a pretty flexible clamping set up and doing the actual welding. I'd keep an anvil or stump nearby to do any real pounding on.
I decided to get a second one today ($45 with the 25% off coupon). In looking at how they set up the guides, they have predrilled holes with captive nuts on all four sides of the top. That means, I think, that I can attach two of them together easily in either a 20x60 or 30x40 configuration. Knowing that my Nomad always seems a bit cramped, the option of putting two of these puppies together, even if just next to each other but not secured, will make the work space more efficient.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #27
I agree. I think I'll pull the trigger on 1 or 2 myself. :cool:
   / Harbor Freight copies StrongHand Nomad welding table...$59 #28
Did you see the Stronghand connector plate? Might be able to copy it. Too bad it costs more than the whole thing from HF.
Strong Hand Tools Nomad Table Connector Plate, Model# TSL30 | Welding Screens Tables| Northern Tool + Equipment
You guys just cost me $45 by the way. I'll put mine together in the AM.
I had the exact same thought. Although the $60 plus shipping StrongHand connector is nice and better than just a piece of 14g steel with 1" flange on each side, the simple steel is the cheapest solution. The other is to just get a third HF model and cannibalize it for the top. $45. Probably couldn't get a metal shop to supply and bend plain steel for that price. Besides, think of the cool project you could do with the perfectly fine left over stand.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #30
I guess I am missing something. Why not just reinforce the edge (if it needs it) with a small angle iron, and bolt one table to the other directly? I don't understand the point of the connector plate.
2017 Dodge Charger Sedan (A55758)
2017 Dodge Charger...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A55218)
2012 New Holland...
BUNDLE OF 60" X 23" EXPANDED METAL (A54756)
BUNDLE OF 60" X...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
