Harbor Freight plasma cutter $500
   / Harbor Freight plasma cutter $500 #1
HomeBrew2
Banned
Dunlap, CA
Kubota BX23
Seems like a new product ... any opinions on this unit.
   / Harbor Freight plasma cutter $500 #2
If I am not mistaken, these have been discussed in detail either on the Miller Motorsports forum or the Hobart welders forum .
The biggest drawback mentioned was repair parts and consumables, especially consumables. I believe that the tips can only be bought thru HF.
You will also need a source for CLEAN and DRY air. This is most important since if effects consumable life.
I have a Miller Spectrum 375 plasma cutter and it was well worth the extra money. I use 3 air filters, the one on the compressor, another at the cutter and finally a MotorGuard after that. Gotta have that dry air. /forums/images/graemlins/smile.gif
Thanks for the links!
Nice looking outfit!
   / Harbor Freight plasma cutter $500 #4
I have one - other than the On/Off switch sticking a bit it works just fine so far.
</font><font color="blue" class="small">( The biggest drawback mentioned was repair parts and consumables, especially consumables. I believe that the tips can only be bought thru HF. )</font>
Actually consumables should be no problem - you can source them here:
HTP America Plasma Parts web page
Three filters here as well .... I used the money I saved to buy the MotorGuard filter /forums/images/graemlins/grin.gif
Great tip, thanks for the link!
   / Harbor Freight plasma cutter $500 #6
I borrow my neighbors frequently. It is not new and cost him a bit several years ago. I hook right on to the air compressor and give her heck, no dry air or filters. It needs to cut and cut it does. The two tip parts seem to last forever in a consumer type environment.
THAT is very useful info!!!! I was really wondering about the performance of the consumables under non-optimal conditions.
Thanks! Cheers!
   / Harbor Freight plasma cutter $500 #8
He had bought a 5 pack of each of the two tip parts and we've tried to replace them because the cut wasn't pretty but it didn't help, then we discovered that clean metal and good ground are just as important when plasma cutting as they are with welding.
Honestly, the plasma cutter is an accurate gasless torch to me. If the impurities from wet air cause porosity in the slag then that's OK.
Gee whiz, I was just looking for gasless and portability with a finish better than hogging with a wet rod and a buzzbox ... accuracy and cleanliness would be fine as a treat. Thanks mucho for the info.
   / Harbor Freight plasma cutter $500 #10
Why not just add a refrigerated dryer? Mine sets on the outlet side and I haven't had a need for any extra filters whether with tthe plasma or a paint gun.
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
SORKO MC19-10 LOT IDENTIFIER 136 (A53084)
SORKO MC19-10 LOT...
UNUSED AGT 3000 PSI HOT WATER PRESSURE (A51248)
UNUSED AGT 3000...
Antique Horse Drawn Plow (A51573)
Antique Horse...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
