radioman
Super Member
thats a good mod to make. I havent bent mine yet, and I used it quite bit already. I too bolt it to the floor and take it out when I am done. I find that I only need 2 bolt, not 4.
Just the slats rotating the jig so that no two bolts were on the same slat. If you use a beefy pallet, it will last a while, but even with a weaker one, it always worked well enough to work on 4 tires. For $50 its a great tool, but I don't use it more than once or twice a year.
1. I drilled into the concrete and installed 4 3/8 inch anchors. I simply bolt it to the floor for use, then remove it when done. The process takes about 5 minutes. The unit is set up in an area that my wife parks in, in a two car garage.
2. The bead breaker is the same unit that came with the machine. I cut a couple of plates to attach to the two legs that attach to the pipe via a clevis pin. I then welded the plates to those legs at the bead breaker shoe, and about 2.5 inches below the top of the legs. There are two plates one on the front and one on the back of the legs. The pipe goes into the adjustable pipe that attaches to the legs of the bead breaker; it is thick wall pipe I got from work, and looks like simple black gas pipe.
3. I do not have the Ken Tool Snake yet. I know that Ken Tool has a distributer here but can bet that when I go to see them they will tell me that they have to order it, this seems like the way of life here in Wichita. After I see them and verify their price I will order it from them or on line. I know they can be had for about $52.00 on line.
Harbor Freight does not have a Ken Tool Snake knock off. I bet I would bend it if they did.
4. A 4 foot snake would be a bit over sized, but I bet it would be manageable.
5. Answered in question 3.
Anytime,
David
30 + years ago when I worked with road tractor tires. A old man showed me how to brake down the tough beads just put a little gas around the bead be for you start and they will all most fall down by themselves
