Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #10,391
Not really Harbor Freight related, but the only Phillips bits I will buy are the DeWalt "Tough Grip" bits. They seem to strip out Phillips head screws much less than any other bit that I have tried: https://www.amazon.com/DeWalt-15-Pack-Phillips-Screwdriver-DWA1PH2-15L/dp/B07JPJMLTG/
Aaron Z
My go to #2 Phillips bits are Bosch. Found they were the best for SS screws that are used on boats.
I have tools from all manufactures. All have done the job that they were purchased for. Some of them are 30 years and older. Biggest failure are switches and batteries on power tools. Latest failure was a 6" HF polisher. But it held up for 25 waxings of my 35' Motorhome.
Here is a list of who makes/owns who.
Tool Brands: Who Owns What? A Guide to Corporate Affiliations
   / Harbor Freight Tools that don't suck #10,392
Same here. Like those bits a lot. Long lasting, too.
   / Harbor Freight Tools that don't suck #10,393
They look like they might be copying the Snap On design that started back in the late 80's where the drive faces have raised ridges that bite into the screw and prevent the bit from being shoved out of the screw under pressure.
That is part of it, but I think another large part of it is that the wings for the Phillips bit go all the way out to the outside of the shank rather than stopping short like most other bits do.
That means that it will bite all the way to the edge of a Phillips head screw versus only biting on the center 2/3 of the screw like most other bits do. If you put it next to a #3 Phillips bit, the wings stick out as much as #3 Phillips bit, but the center section is smaller.
The upside is that you are less likely to strip out the head of a Phillips screw.
The downside is that if you strip the head of a screw out there is no way to get it out short of drilling it out.
Aaron Z
   / Harbor Freight Tools that don't suck #10,394
Techtronic, the parent company for Ryobi and Milwaukee and contract mfr for Ridgid brand, sell Ryobi and Ridgid refurbs and blems here:
Direct Tools | Factory Blemished and Reconditioned Ryobi Power Tools, RIDGID Power Tools, STOK Grills, ... |
I've ordered a few items from the web site. Generally good. Sometimes the items are in poorer condition than expected, but the customer service is responsive and they quickly make it right.
That is a great find!!
I see the Ryobi ZRP825 kit for $45 as a 'Black Friday Special', Home Depot's price is $99. This is a Li-Ion battery, charger, 5.5" circular saw, and 1/2" drill/driver. Another special is four batteries for $80.
Through Sunday 11/25 only.
   / Harbor Freight Tools that don't suck #10,395
The 4 batteries on the special look like 1.5AH, right now Home Depot has the 4.0 AH 2 packs for $79 which is a little more bank for the buck if you are looking for some.
   / Harbor Freight Tools that don't suck #10,396
The 4 [Ryobi] batteries on the special look like 1.5AH, right now Home Depot has the 4.0 AH 2 packs for $79 which is a little more bank for the buck
Each type has its place. I like the lighter batteries for the jigsaw, string trimmer, pole saw, anything where I am continually lifting the tool. Power is fine and that's less tiring. It's simple to swap in another battery if I exhaust one. The heavier double size seem better where the tool will be run hard - chainsaw, circular saw - but in actual use I don't see much difference except longer run time.
Here's the hardest application I have encountered so far, clearing the haul path on this terrace cutting 10" and more Eucalyptus (very tough) with the 10" chainsaw. There were spots where I had to cut from both sides. I thought this would smoke the saw but its fine. As I noted above, I recently found a second saw motor so now I can be a little less cautious about running this saw hard. I might jump up to HF 40 volt gear if I smoke both these saws. Anything is better than maintaining fresh 2-cycle fuel for very intermittent use.
474385d1468344241-harbor-freight-tools-dont-suck-kimg1634rsawdowned-eucalyptus-jpg
   / Harbor Freight Tools that don't suck #10,397
Looks like it did a good job! Been thinking of a Battery powered saw for on the SxS when we go riding. Normally I would need it for far less than you used one there and on softer wood!
   / Harbor Freight Tools that don't suck #10,398
I didn't realize that Ryobi made an 18v string trimmer. How do they stand up? Run time OK? Haven't heard good things about their 40v lineup. Got several other 18v ones, and they've served me well.
Was kicking around the idea of replacing my gas one with the Lynx 40v. As you mentioned, keeping fresh fuel for something I use maybe once a month in the summer is a PITA...most of my 2 stroke tools are relatively forgiving of stale fuel, but this one is very fussy.
   / Harbor Freight Tools that don't suck #10,399
I say this as a huge ONE+ fan: The performance of the 18v string trimmer is poor. It really only handles very light growth (think minor grass around a garden edge). Anything heavier will bog it down. At least, that was my experience. Run time with 1.5ah battery was perfectly acceptable. I just couldn't cut anything meaningful with it. Makes a handy tool for light work in an already well groomed area.
   / Harbor Freight Tools that don't suck #10,400
On the subject of battery powered saws -
I bought a Black & Decker 40V 12" chainsaw (10.2 lbs) a few years ago. Very good for $120, I was able to frequently use it one handed for trimming limbs while I was up on a ladder. But I "lent" it to my daughter in Maryland.
So I'm down in Mississippi and needed a chainsaw to use while I was up a ladder. I bought the HF 40V 14" (13.35 lbs). It was like going from my Stihl 021 (35CC) to my JD CS 62 (62CC). Lot more power but also more weight. I really think the HF could easily handle a 16" bar whereas the B&D couldn't handle more than it's 12".
The Lynxx pole saw AND chainsaw are great tools, I've read poor reports about their sting trimmer.
I recently bought a DeWalt Flexvolt string trimmer, partially for the battery.
Year: 2020 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 87,543 (A56859)
Year: 2020 Make...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
3 Forks (A56857)
3 Forks (A56857)
2015 NISSAN Pathfinder SUV (A56859)
2015 NISSAN...
Mini Excavator 9 Piece Attachments (New/Unused) (A59225)
Mini Excavator 9...
2020 Takeuchi TB235-2 (A55272)
2020 Takeuchi...
