Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #13,621
Either of my large frame Kubota's can move one dressed out or devoid of stuff, no issue. My impetus for building it to be portable is placement during different seasons. Winter placement would differ from summer placement in my situation.
I'm with you on seasonal placement. :thumbsup:
   / Harbor Freight Tools that don't suck #13,622
I've had a few bigger than normal purchases lately, and some good stuff came out of it:
Bauer 20V bluetooth stereo, it's pretty nifty, once paired to your phone and in bluetooth mode it will automatically pair and play music without you getting into a music player again on the phone, and the 3AH battery lasts for a LONG time even with the volume maxxed out, so far I'm on 4+ hours and the battery still shows full charge and the volume is maxxed... it is a fair amount louder than the other bluetooth speakers I have and it has better features like the ability to run FM/AM radio and aux input as well as charge a phone while playing
Smith Jones 2hp motor, this was an ordeal since their old 2hp motors apparently were 3450rpm instead of 1800rpm and had a 1/2" shaft instead of 7/8" but I got it working... cost a $40 amazon pulley but I got it hooked up :). I have several hours on it now and it is running the compressor I put it on pretty good, very quiet and smooth.
Banks 21 degree framing nailer works decent, I've put a few hundred nails through it and it doesn't always drive them in far enough, probably need to up the regulator pressure but the compressors pressure switch isn't set very high so it isn't consistent when it turns off at 110psi and turns back on at 80psi...
Central Pneumatic 100' orange air hose they're on sale now for $16 so I picked up another so I can maybe get another nail gun going this weekend... it's kinda prone to kinking and tangling but less so when aired up, I have the short version in my garage going to my retractable reel from the compressor and it's weathered pretty well (better than the black "premium" Diablo hose on the reel).
   / Harbor Freight Tools that don't suck #13,623
Anyone have any experience with the HF 32860 spark plug cleaner?? It looks similar to others on the market but is about 15% less cost.
   / Harbor Freight Tools that don't suck #13,626
I use a oil furnace ignition transformer. It's designed to light diesel fuel. I place the plug between the two terminals and then plug it in. You need to be cautious as it's high voltage but in moments the arc will burn off everything. Even fouled plugs don't stand a chance. The plugs will get very hot. I've never been keen on sandblasting a spark plug. Seams like you would remove any plating on the steel parts. You would also need to clean it very well to avoid getting grit in the engine. As for the HF style plug cleaner, they all look like they are made in the same factory. I suppose there could be different types of grit that could make a difference but otherwise they seam very basic.
   / Harbor Freight Tools that don't suck #13,627
I have one, it works fine, I just have it loose but might mount it in the shop once it's done...
as long as it's dry you shouldn't have much grit left on the plug, there's a lever to put just air across the plug to clean it off, another spray once out of the cleaner would get the rest of it...
Good for small engine plugs, but if you have anything else that is fouling plugs you should really get it fixed or replaced since that isn't a good sign!
   / Harbor Freight Tools that don't suck #13,628
I'm cheap but not that cheap. New spatkplugs don't cost all that much in the first place.
   / Harbor Freight Tools that don't suck #13,629
No but when the local store that might have them is about an hour away and depending on what day or time may not even be open it's always nice to have an option. Also if you have a 2 stroke that has bad fuel or something in it and keeps fouling plugs it beats throwing out a new plug that got fouled immediately. It's also a great way to see if a plug is fouled. If the spark looks weak or isn't jumping from the tip of the center electrode you know you have a problem with the plug. An old Frenchman showed me the trick, actually he taught me several tricks.
   / Harbor Freight Tools that don't suck #13,630
I have to tell you, when I get a fouled plug in a 2 stroke (rarely), I take it out and take my propane torch and heat it up and dry it out (electrode end) and put it back in. Always cures the issue for me.
7ft Metal Texaco Pump (A57454)
7ft Metal Texaco...
Cushman Hauler 800XE Electric Utility Cart (A56857)
Cushman Hauler...
2018 Chevrolet Silverado 4x4 Service Truck, VIN # 1GC1KUEY2JF129960 (A57453)
2018 Chevrolet...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2014 MACK CHU613 FRAME (INOPERABLE) (A58214)
2014 MACK CHU613...
Metal Grizzly Bear Statue (A57454)
Metal Grizzly Bear...
