Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #6,591
Gotta figure it's worse for the other ***.
   / Harbor Freight Tools that don't suck #6,592
Particularly if she trades sides of the bed the next night.
I thought the correct modern spelling was "hafta"
   / Harbor Freight Tools that don't suck #6,594
Silver And Deming Drill Bit Set 9/16 to 1", with 1/2" shanks, $35. After 25% coupon = $26.25. Any good?
I've got a set like that (mine goes up to 1 1/4") and have only used them but only to chase and clear out existing drilled holes or expand an already drilled hole by a small amount like 1/16th or so. I used a drill press with cutting oil and for my purpose they worked fine. They stayed sharp and worked well with no burring of the drill edge. I went slow speed and they cut clean.
That's all I have done with them because I lack the confidence to try to drill a new hole. They look and feel like they would do it but someone else will have to answer that part. Hope my comments help.
   / Harbor Freight Tools that don't suck #6,595
Need a coupon?
   / Harbor Freight Tools that don't suck #6,596
I also have a set of them. They are good but you have to be sure to securely clamp whatever you are drilling with them. Don't attempt to drill with a hand drill because if the bit catches it will twist your arm off. Same goes for using a drill press. Never try holding what you are drilling. If the bit catches it will rip it right out of your hands. Been there, done that.
   / Harbor Freight Tools that don't suck #6,597
25offFF_print.jpg Got this 25% off coupons this morning and it said it can be shared
   / Harbor Freight Tools that don't suck #6,598
My experience has been the same. I have the same set, I use it in the drillpress and have been happy with it. I only have 10-20 holes drilled with it though, but I always use cutting oil (CRC foaming cutting oil purchased from HF).
Aaron Z
   / Harbor Freight Tools that don't suck #6,599
You really want to step drill with these things, that 1/2 shank isn't enough to take the torque of pushing a bigger drill thru. I'd drill with a 1/8, then a 1/4, then a 1/2, then to a 1 inch or more. IMHO, you need clearance for the web on the bigger drills. I've got that set, it works fine, but my little drill press isn't up to putting a big hole in a hunk of steel either....:)
And coolant helps a lot!
2007 Ford E350 (A55973)
2007 Ford E350...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
8065 (A55852)
8065 (A55852)
