Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #8,421
I had one female fitting on the end of an air hose that wouldn't seal after I took of an air chuck that had been on it for months. Aside from that, no leaks, no problems.
Oh one other issue - it is nearly impossible to engage them under pressure. You can do it, but its a lot easier if you bleed off the air pressure first.
As for more air - the $20 HF impact wrench used air like crazy. My 10 gallon compressor would start after a couple of lug nuts. I felt the larger fittings delivered more air and improved that tool's torque. Later I tossed that and got the $75 Earthquake that needs a lot less air. I'm not sure the big fittings do anything for it.
I've had several Earthquakes from the very beginning over 10 years ago and get the best results from higher air pressure. I know they say 90psi but I have a 100 ft hose the air has to go through plus the small connectors. I use whatever pressure is in the tank and it's often 150psi ---at the tank--- .
After the100 ft hose and connections figure in, it may drop to 125 or so but I have never had a problem and I have used air tools a lot and under bad conditions. I do oil before the start of each use, however. Presently, I have an Earthquake XL and run with the same pressure as always. No problems and great results.
   / Harbor Freight Tools that don't suck #8,422
Well, I just had a garage fire. All is OK, none one hurt, house OK, but all my tools destroyed.
The funny thing is, my tools are either Craftsman, S&K or Pittsburgh.
The chrome burned off my Craftsman and S&K stuff, and they are rusted and shot. My Pittsburgh stuff fared much better and some look like you could wipe them off and use them.
The temper is gone in everything, so kind of irrelevant, but I thought it noteworthy that the HF tools held up to 1400+ (I know it got this hot because a bunch of large aluminum items melted) degree temps and two name brands didn't.
Well, God bless, and thanks for the information re: the durability of my primary/predominant source of tools [not that I don't have a bunch of Craftsman and even Snap-On tools too- just not as many as the HF and TSC brands.]
I thought that the name of your town was familiar, and when I checked its wiki, I found out why.
I used to drive through/past there every weekend while I was doing my surgical rotation in Bethlehem, PA at St. Luke's Hospital when I was in PA school at King's College in Wilkes-Barre, PA. I would have to drive to W-B every other w/e, and would come home to the Rochester, NY area on the other w/e's.
Best of luck to you in your rebuilding of both your garage, and tool inventory.
   / Harbor Freight Tools that don't suck #8,423
This silver tarp 11' x '19' is junk. I put it up in May, replacing one that had lasted a reasonable time. It seemed lighter than the HF tarp I took down.
By year end it had frayed and tore in half. I thought it was abrasion but when I took it down I see the material simply rotted from the sun. I went to cut it up with scissors to make painting tarps and it was so rotten the scissors slid along with no resistance. It cut easier than newsprint and tore with even less force. About a quarter was so rotten it would break when folded over.
Avoid.
I've used similar tarps from Ebay that lasted two+ years, and read good reviews for tarps from Grizzly. Maybe HF's green HD tarps are better.
   / Harbor Freight Tools that don't suck #8,424
Avoid.
This is one of those posts that belongs in the original "Harbor Freight Tools That Suck" thread. Can't seem to find it though. Hmmm, maybe that's why he didn't post it there. Have to agree with California about the silver tarps. Same goes for the silver ones from TSC.
   / Harbor Freight Tools that don't suck #8,425
I like the large tarps from Costco. They're about $20 for two tarps, but they seem to last between 3-5 years before needing replacement. (I know, getting way off topic).
   / Harbor Freight Tools that don't suck #8,426
Naw, not that far- if you can't digress occasionally what's the point, and a recommendation for something better is pretty much always welcome.
   / Harbor Freight Tools that don't suck #8,427
Recommending a better alternative to a deficient HF product is right on target, in my opinion!
   / Harbor Freight Tools that don't suck #8,428
Agreed, as long as it is fairly price competitive. The point of buying HF stuff IMO is mostly cost.
   / Harbor Freight Tools that don't suck #8,429
2+ for that- Although I think you could also argue that it's obvious we are all here because we're on a constant search for the best available value [that slippery multi-factoral ratio between the best possible, the lowest price, and exigent need- either immediate or future] than just lowest cost PERIOD.
   / Harbor Freight Tools that don't suck #8,430
I've seen those at Costco but just presumed all blue tarps were the same. Are these better than HF? How much better?
Well, yes and no. The smell of evaporating rubber and the hunt for some object we have yet to evaluate brings it's own chase.
That's why I go.
2016 Volkswagen Jetta (A56859)
2016 Volkswagen...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
