Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #1,031
Has anyone tried the handheld bandsaw? $90, 4.5" capacity.
Yep.... It has been one of my best HF purchases. I can't believe how well it works. It has already saved me a ton on bi-metal sawzall blades. It's one of those tools I don't know how I got by without it. The weld in the included blade is the only drawback. Sometimes you feel a little bump when cutting.
Ok, I bought it. After sale price and 20% coupon it was $67.99.
Somewhere I saw that the original blade is for wood and I need to buy a finer hacksaw-like blade before using it on metal.
Any advice?
   / Harbor Freight Tools that don't suck #1,032
#42661 Strapping Tool Set -
This is for cinching up plastic straps around shipping cartons or bundles of lumber, then crimping the clip that joins the ends of the strapping.
This set is no longer sold. I have it, with its carton and manual which is dated 2000.
Does anyone have this? Where do you get more strapping, and the clips? It looks to take 3/4" strapping, that is the size of the jaw opening on the crimper, but it could also be 3/4 jaw opening to fit over 5/8" size clips before crimping them.
Does anyone have some experience with this tool or something similar?
   / Harbor Freight Tools that don't suck #1,033
My original blade cut a lot of metal before I replaced it. A lot of crap and it held up better than expectation.
larry
   / Harbor Freight Tools that don't suck #1,034
Thanks! I'll simply put it in service then. With only occasional use that blade should last me a long time.
Edit, Update! I opened my saw. It has a decal that I now remember was on the store demo (but it's not in their online photo, or the manual):
Something like "The initial blade shipped with this saw is for wood only. For cutting metal, get a metal-cutting blade."
Looks like my next stop will be Lowes for a real blade before I can use it.
   / Harbor Freight Tools that don't suck #1,035
i operate an automated strapping machine at work. we also have a hand model for stuff too small for the machine. signode is the manufacturer of both (and i have seen the signode name on other crimps that have come through the plant). searching for signode could get you started.
if you lived close enough, i could get you a lifetime supply of plastic strap, but it's only about 1/2" wide. i go through 2 or 3 60lb rolls in 8 hrs.
   / Harbor Freight Tools that don't suck #1,036
searching for signode could get you started....I go through 2 or 3 60lb rolls in 8 hrs.
Thanks! I'll look for that name locally.
You must be strapping huge quantities of something to use that much!
PS for the bandsaw, I got a couple of 'Standard' Milwaukee brand 18 tooth blades. Home Depot had several, all 18T, as part of their Milwaukee display. I wonder if these are better than the bi-metal blades at HF? Probably!
   / Harbor Freight Tools that don't suck #1,037
I would have to give a thumbs up on this set.
3/8" to 2" Ratcheting Pipe Threader Set
I have done enough not to have gotten the use from the kit.
On thing I wondered if anyone has used it and replaces the cutters in any of the heads, and are they standard?
I used alot of oil and reversed often to clear the head. The powered one looks interesting .If I had know it was this handy I would have bought the powered one.
Wonder if the heads are the same .I could buy the powered one and the set I dont have.
   / Harbor Freight Tools that don't suck #1,038
Northern Tool sells some of the strapping stuff.
http://manuals.harborfreight.com/manuals/42000-42999/42661.pdf
Stretch Wrap + Strapping Materials | Material Handling | Northern Tool + Equipment
   / Harbor Freight Tools that don't suck #1,040
saw some at grainger too...didn't check mcmaster.
Thanks Brad and Defed. The Northern Tool strapping supplies look like the right ones.
My crimping tool looks like this one at NT. The openings in the chrome outer plates measure 3/4". Does anyone know what width strapping that is intended for? I'm guessing that notch is oversize to slip over the 'seals' that get crimped, no?
I see NT's strapping is sold by (nearly) mile increments, however. I need to find a local supply who will sell me a few hundred feet off their spool.
My use is simply to band a dozen or so pallets of redwood lumber, various odd sizes intended for future projects, so I can move them around without spilling them. I was using cheap poly rope but discovered it rots after a year of sunlight so my stacks are unstable. Something I can cinch up tighter will be a lot better.
401 (A52706)
401 (A52706)
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2007 CHEVROLET KODIAK C6500 (INOPERABLE) (A55745)
2007 CHEVROLET...
