Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #3,441
I've eyed that electric cut off tool a few times as well. The air powered one bogs down even on my 60 gallon, 5 HP compressor. I have the electric 14" metal chop saw and it works ok if you aren't too picky about getting a clean cut. Motor bearings aren't that good and it wobbles.
I would imagine the small electric cut off tool would have the same problem, albeit on a much smaller scale.
I'm thinking that the electric cutoff tool might actually be a good idea. Sure wish someone here owned one for a testimonial. Maybe I'll just gamble or maybe see what Lowe's or Home Depot offers. Electric motors at HF still seem too hit or miss on quality.
   / Harbor Freight Tools that don't suck #3,442
It actually has really good reviews on their site. It seems like most of the reviews I have read on their site are pretty accurate. I've noticed that when something gets really bad reviews, it usually goes on clearance. I think I may buy one myself..
   / Harbor Freight Tools that don't suck #3,444
I have the air powered 3" cut off tool that works fine but it bogs down sometimes. I have been thinking about the electric 3" tool--same 3"--since it gets good reviews. I wonder if it has more power than the air powered one? I can get it for under $20 now.
Here's the electric one. It seems to work well. Does anyone own one of these that can comment?
120 Volt 3" High Speed Cut-Off Tool
and here's the one I currently have that seems underpowered even at high PSI and plenty of air.
3" Variable Speed Air Cutter
Thanks in advance.
I have one of those air powered cut off saws, had it for 20 years or more. It's got a plastic body (think it's aluminum underneath). Mine was also underpowered with my 5hp compressor. The only time it really worked well was when I used it at a friends shop who had a 13hp gas 2 stage compressor. Way too much power needed to turn it. I figure it's like an air powered drill, it has to have a real advantage over an electric or battery powered one to make it worth while.
I love these free multimeters for trouble shooting stuff.
Display
   / Harbor Freight Tools that don't suck #3,446
Display
I keep one in each vehicle. Great for when you have a problem with trailer lights, etc.
   / Harbor Freight Tools that don't suck #3,447
I really need one, but I may just have to buy one. The closest store is 1.5-2 hours away, and the coupons are only good for in-store use? Oh well..
   / Harbor Freight Tools that don't suck #3,448
I just bought a bench grinder stand, and it works great! It actually went together seamlessly, had the exact number of bolts, and is pretty heavy duty. I am very impressed, and it freed up about a 1 square foot area on my workbench. Universal Bench Grinder Stand
   / Harbor Freight Tools that don't suck #3,449
Here's a coupon for Memorial Day only. Can always use a free tarp.
memday
   / Harbor Freight Tools that don't suck #3,450
Me too. I got one a couple of months ago. The grinder is on it now. Highly recommended.
I'm considering buying another to mount a heavy vise.
I also bought the cheaper of their two grinder pedestals of the type that has a round column and a cast iron top. I clamp welding projects to it temporarily. It works great as a 'welding table' that I can put away after use.
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
LOT: Misc. Oils, Coolants, Tires (MOST OPENED OR PARTIALLY USED) (A59076)
LOT: Misc. Oils...
Golf Cart (A55787)
Golf Cart (A55787)
40' CONTAINER (A52706)
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2019 INTERNATIONAL...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
