Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #10,601
I'm surprised the solar charger is powerful enough to do that but I know the HF $5 'float charger' will eventually cook the water out of a battery if it is left on for weeks. BTDT.
I've have (had) a number of them.... I found some charging as much as 16+ volts. Threw those out. I check them before using. They're ok. End up buying better ones. Really not worth the risk...!
   / Harbor Freight Tools that don't suck #10,602
The 5 drawer upper bin is deeper (up and down), the 4 drawer one is shallower and does not fit larger screw driver handles dropped down into the holes. The 5 drawer is deeper and more accommodating here.
But the 4 drawer holds taller items/bottles underneath. Its all about what you need it to do.
   / Harbor Freight Tools that don't suck #10,603
Wow, I knew a midniteoyl on another board a long time ago. Used a green fuzzy critter as an avatar.
   / Harbor Freight Tools that don't suck #10,604
Actually, no. The difference is actually about a half inch since what they did is raised the top to make the added depth.
The 5 drawer cart also gets the aerosol shelf standard.
Also the fold out, add on side shelf is much larger at 300 SQ inches compared to 210 SQ inches on the 4 drawer tech cart.
The 5 drawer gets you actual latching drawers like the larger toolboxes have rather than the detent style slides on the smaller 4 drawer cart.
It's only money, but the tool cart is a lifetime purchase. 20181219_153843.jpeg20181219_154332.jpeg20181219_154346.jpeg
   / Harbor Freight Tools that don't suck #10,605
Not sure I've ever used an avatar like that, but have been using this name since the 90's so could be :)
   / Harbor Freight Tools that don't suck #10,606
Actually, no. ...
Now I'm confused. I hate being confused. Could have sworn it had ~3-4" more height clearance. Gonna make me get up and go figure this out.
   / Harbor Freight Tools that don't suck #10,607
Look at the photo, I put them side by side... Visually take the aerosol shelf away and you see that you have nearly the same exact vertical space between the 2. If you want, I'll go back tomorrow and jam a tape measure in both to show you the numbers. For all intents and purposes.... The bottom shelf height is same same.Toolbox%20comparison.jpeg
   / Harbor Freight Tools that don't suck #10,608
Look at the photo, I put them side by side... Visually take the aerosol shelf away and you see that you have nearly the same exact vertical space between the 2. If you want, I'll go back tomorrow and jam a tape measure in both to show you the numbers. For all intents and purposes.... The bottom shelf height is same same.View attachment 583667
I'm confused, not blind ;)
   / Harbor Freight Tools that don't suck #10,609
They had all sorts of after xmas & new years sale papers at the front counter..
The 4 drawer box will be 2.00 cheaper after xmas.. LOL
Can I use a 20% off coupon WITH the SUPER coupon for the box.??
I too was thinking about getting 2 of the 4 drawer..
Did anyone else brows thru those papers?? 1 of the freebies is a "head lamp lite" now..
   / Harbor Freight Tools that don't suck #10,610
You can not stack a super coupon and a percent off coupon, besides... The 20% off does not work on tool storage or 3/4 of the stores contents.
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2013 CATERPILLAR 259B3 SKID STEER (A52709)
2013 CATERPILLAR...
