Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #11,071
Anybody tried the new Titanium 225 stick welder yet? Or have experience with the small, portable inverter stick welder?
Thinking about getting one of those, wondering if the new model is worth the extra $100.
   / Harbor Freight Tools that don't suck #11,072
There is a youtube video comparing the Vulcan and Titanium HF welders. Did a decent job of explaining the differences IIRC.
   / Harbor Freight Tools that don't suck #11,073
As far as harbor freight tools go the $15 dollar grinders are a heck of a deal. And just for grins after one finally ate its first set of carbon brushes which are pretty short to start with, I decided to see if I could get parts to fix it with. Chicago Electric ie Harbor Freight was NO help. After getting the 3rd call back Monday type message, I decided to Google it.
I ended completely disassembling it. I turned the armature on the lathe polished and undercut the commutator and greased the bearings and drive gears. After measuring the brushes I found a source who was selling the right dimension ones on line. When I got the 2 pairs of brushes for $3 dollars I had to use my old brush springs because the ones that came with the new ones were too long. Price was right. Hope they weren稚 radioactive.
Put it back together the thing runs almost perfectly vibration free way better than my Ryobies. I will use it until the gears finally go out. Perhaps by then I値l have another donor machine to use the armature in since it痴 so well balanced now.
I may try tuning up my Ryobies next. I think they actually will sell you name brand brushes for those. They come out of Seattle or Portland.
   / Harbor Freight Tools that don't suck #11,074
Almost forgot. I bought one of their big 2 cylinder compressor pumps when I built my portable air compressor. After probably 5 years of use it still pumps just fine.
And as an added opinion their $14 1 pint gravity feed paint spray gun works great when you first buy it. Only after you try to clean it and find that they designed a couple fittings with reverse threads that shear off when you turn them the wrong way will you know that the thinner you use costs more than a replacement.
   / Harbor Freight Tools that don't suck #11,075
My cheapo grinder from HF CAME WITH extra brush's..
I used it for the 1st time to cut open a seized head & rotor on an injection pump.. SOLID STEEL..
It worked flawlessly.. I was impressed.. & their grinding wheel that goes on it {4-1/2"}held up great too..
   / Harbor Freight Tools that don't suck #11,076
I have the old small inverter stick welder. It's great for small stuff ... and by small stuff, I mean it won't burn anything over 3/32". Period. Every 1/8" rod I've tried just sticks. There's just not enough power there.
   / Harbor Freight Tools that don't suck #11,077
Out of all the extra sets of brushes I've got lying around, I've only replaced one set. The old ones weren't worn out, then. I replaced them because I didn't know what else to do and I had the brushes. They didn't solve the problem.
   / Harbor Freight Tools that don't suck #11,078
I've burned up two of the $9.95 angle grinders. Their proper application is a wire brush wheel or similar that doesn't need huge torque and won't be run continuous. They are fine for that.
First one the plastic fan disintegrated after 20(?) years of infrequent use cleaning welds with a wire brush wheel. It still ran but I gave it away.
Second one I mounted in the 'cutoff saw mount' from Northern Tool that I described in this recent post:
https://www.tractorbynet.com/forums...-freight-tools-dont-suck-528.html#post5287449
That worked well until it didn't. A couple of minutes running continuous slicing a 7/8" bolt and it faded away, smoking, just as it finished the cut.
I like that cutoff saw mount but I'm a little leery of putting a more expensive grinder in it. I think it needs a very light touch feeding the grinder into the cut.
   / Harbor Freight Tools that don't suck #11,079
So, y'all smoke grinders too out there in Californey?
   / Harbor Freight Tools that don't suck #11,080
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2014 Infiniti QX60 AWD SUV (A53424)
2014 Infiniti QX60...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
2013 JOHN DEERE 27D EXCAVATOR (A52707)
2013 JOHN DEERE...
2019 CASE IH Steiger 500 QuadTrac Tractor (A53485)
2019 CASE IH...
