Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #13,551
Does that reduce the life of Li-Ion batteries by draining them to the shut off point? Are they better off maintained with a mid to upper charge range, occasionally topping them off rather than fully draining them?
Lithium-Ion batteries "like" to be in the (roughly) 20%-80% range (and good lithium-based equipment will have a protection mechanism built in to shut down - usually to protect from over-heating, but it may also protect from too deep a discharge). Running them outside that 20-80% range is not a huge problem, but you don't want to leave them that way for extended periods. Standard flood lead-acid and AGM batteries like to be kept full. Lithium batteries are a bit different: for long term storage, it's best to leave them somewhere around half full. My Milwaukee M18 batteries have a 4-light charge indicator. If I'm putting them away and won't be using them for a while, I try to leave them with either 2 or 3 lights showing. Storing this way is supposed to maximize the years of life you get out of the battery.
   / Harbor Freight Tools that don't suck #13,552
I believe that Li ion batts that are in storage a long time are like any other ion-rich battery regardless of the chemistry.
They last best & with least aging if stored at about half charge. And if they are stored with a full charge they will probably drop to the half way point anyway.
   / Harbor Freight Tools that don't suck #13,553
That protective shutdown should save Li-Ion batteries from damage but I lost one on a Ryobi jigsaw. I discovered the laser light for aiming the cut, had been bumped on. Apparently when I set another tool on top of it in storage. Don't do that. :mad:
   / Harbor Freight Tools that don't suck #13,554
Two things.. It needs a hard case to sit in... and a different name!:laughing:
   / Harbor Freight Tools that don't suck #13,555
Sort of like my drone. The Li-Ion batteries for it, if you full charge them, will drop to half charge over a period of days without being in the drone.
   / Harbor Freight Tools that don't suck #13,556
So speaking of your drone and Li-Ion batteries.. Do they just turn off when they start to get low like all the ones I've seen? And if so does your drone just drop from the sky!?
   / Harbor Freight Tools that don't suck #13,557
All the Li-Ion tools (I use and own numerous Bauer cordless ones) will cut off flat at a pre-determined voltage, part of the circuitry that protects the battery pack. My Bauer tools do exactly the same. I can be tooling along (pun intended) and wham, it's done. Don't slow down, just expires and if I wait a few minutes, I too can get a tad bit more run time, but not much.
Yes, you absolutely have to do that with lithium because one deep discharge will destroy the cells. Cheap R/C cars & trucks do not include this protection. The cheap ones still use NiMH but a lithium battery is a common user upgrade. Really really needs an add-on discharge safety circuit. The better systems have this built into the radio receiver to shut everything down on low voltage.
   / Harbor Freight Tools that don't suck #13,558
No drop. The internal artificial intelligence monitors the battery charge and output voltage and when it drops top a certain level, the drone returns home to the also pre-determined landing spot. The drone has on board GPS and GLONASS reckoning. You can over ride it but if you do the drone will land beyond your control and then you have to go find it...lol
Called 'return to home'. I think the cheap drones do't have that. Mine wasn't cheap. Wasn't the most expensive either. My wife would shorten my lifespan if I dropped 5 or 6 grand on one. She did a bit of bellyaching at 1200 bucks.:D
It's an Autel Evo btw. Another member on here has one as well. It's Kubota Orange of all colors.....:D
   / Harbor Freight Tools that don't suck #13,559
Some day I'd like to get a drone, my son in law to be has a nice one (no idea what brand) took some pics when he was here last time.. pretty cool what that thing would do.
   / Harbor Freight Tools that don't suck #13,560
The visual perspective aloft is entirely different than on the ground. I bought mine for crop monitoring and I'll need the FAA commercial drone pilot's license as well because I'll use it for commercial purposes. I've already been approached by a commercial grower than wants me to film their planting and harvesting for their website.
I didn't get a DJI because of the built in Geofencing. Geofencing is a program in the computer memory that excludes drone flight around any airport, from the little farm strip to the big commercial one. So long as it's an FAA registered air strip, the done won't operate within a set distance. The Autel drones don't have that and leave safe and legal operation to the user. I have enough regulations to follow without more, so I passed on it.
2015 Chevrolet Sliverado 3500HD (A55973)
2015 Chevrolet...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A56435)
2019 Cadillac...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
NEW Long Forks (A59000)
NEW Long Forks...
