Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #16,331
I just got a 10% off coupon on any item!
   / Harbor Freight Tools that don't suck #16,334
Put a toolbox on the farm truck. Didn't want to put my good hand tools in it and risk losing them out in the field. Bought wrenches 1/4" to 1 1/4" and similar size metrics, similar socket sets both regular and deep with ratchets. Screw drivers and pliers. The screw drivers are too soft and replaced with old craftsman almost immediately. In 10+ years, 1 ratchet wore out, 1 socket adapter 1/2" to 3/8" broke. Both were replaced with no hassle or receipt. Same with a 4 ton port-a-power. Any tool will break and is no better than the guarantee.
   / Harbor Freight Tools that don't suck #16,335
Works great for my light duty needs
A lot of their stuff doesn't suck if your needs are light and expectations are low.
They are certainly better now than 30 years ago. They have learned a lot with the offshoring of American mfg.
Back in the '80's, their drills would twist straight if you tried to drill metal. Their ratchets stripped out instantly and if you used a decent ratchet on the socket, the socket would split into two pieces.
Much better products today also not as cheap.
   / Harbor Freight Tools that don't suck #16,336
Just used the 1/10 horsepower transfer pump. Draining a ditch for a water line. Its not fast, but for the price, it works.
   / Harbor Freight Tools that don't suck #16,337
This hf icon pipe extractor kit saved me a plumbing service call on a cheap Chinese shower downspout pipe hat broke flush with the copper screw in coupler soldered to copper pipe behind a tiled wall. of course I did have to buy the more expensive kit for the size of extractor I needed but still worth it. I also replaced the shower head with a new one to surprise wife lol. Don't waste your time or money on the cheaper Amazon kit like I originally did.
   / Harbor Freight Tools that don't suck #16,339
Update, thank you Topzide for the 10% coupon We just got home with my new Bench Top 8"Buffer. My wife got it for me for Christmas; With the 30% coupon I received today in my email I bought 4 of the Black Poly casters my grabber tool and 2 of the blue 2 way flashlights with the little black hanging hook on the back. They make very nice light and last for a very long time.
   / Harbor Freight Tools that don't suck #16,340
Got their 9" drywall sander the other week. Work great and not allow the dust to contend with! I use their cyclone separator on 5 gal bucket to shop vac with hose on the exhaust to a board cut to fit in window.
The led lighting ring really helps with seeing where to sand.
Some of the reviews said that they have spot sanded wood floors! May need to try as I have a couple of wear areas.
The grit choices are 60, 120 and 220. Not bad choices for what it does.
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
JOHN DEERE 1560 - 15' NO TILL GRAIN DRILL (A52708)
JOHN DEERE 1560 -...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56435)
PENDING SELLER...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A55973)
2022 Power Screen...
Hypertherm Powermax65 Plasma Cutter w/Cart, PIN 083266, S/N 65-067003 (A59076)
Hypertherm...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
