Hard lines to hydraulic cylinder
   / Hard lines to hydraulic cylinder #1
BWSwede
Washington
Yanmar
I have factory hardlines with banjo fittings feeding two of my cylinders. Both fittings on one of the cylinders leak. I have tried tightening them a little but they still leak.
I guess the next thing for me to check is for a seal. What kind should they have?
TIA,
BWSWede
   / Hard lines to hydraulic cylinder #2
I have seen copper washers, steel compression washers, steel with a rubber coating, and more.
Take one off and see what they are
Thanks LD1. I did just what you recommended. I found that one fitting had what appears is a steel (aluminum?) washer top and bottom and the other fitting only had a washer on top.
I replaced them all with fairly wide copper washers. I could not find 18 mm narrow copper washers. So I put it back together with what I had and it leaked like a sieve.
I extended my search further today and found true copper crush washers. Hopefully this will provide the seal I need and withstand 2800 psi (or more with bouncing of the implements).
Thanks again,
BWSwede
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
CASE 580M TURBO BACKHOE (A51242)
CASE 580M TURBO...
