Hardie Plank / Hardie Board siding ???
   / Hardie Plank / Hardie Board siding ??? #21
only thing to use for siding. easy to cut, with the proper blade, use an air gun to nail. another must have honey, but this is a top of the line siding. Make sure to insulate good and seal every plank or the result will be worthless.
   / Hardie Plank / Hardie Board siding ??? #23
I used 4x8 sheets as siding on a shed I built 4 years ago. I considered it an alternative to T1-11.
The stuff has not changed at all, the paint looks as it did the day I rolled it out. We have extreme heat and humidity, and a long rainy season here and although hardie board is no where near as strong as T1-11 it is exponentially more durable or resistant to the elements.
If you miss the stud you could easily put your hammer right through it when trying to nail this siding. I wound up using a nail gun, I think hardi recomends screws that countersink themselves. Also consider that the dust generated is hazardous to your health, it contains silica. I cut it with an old saw blade turned backwards, and implemented a box fan to direct the dust away and down wind. I was cutting it outside, using a respirator.
I would recomend these products, much cheaper in the long run.
   / Hardie Plank / Hardie Board siding ??? #24
I used some of the Hardie 4x8 sheet product for gabel ends of a shed I made. I had a heck of a time nailing it, what is the secret? Otherwise seems to be great stuff.
I used screws that Hardie makes for use with their products. Predrilling was not required.
Later,
Dan
   / Hardie Plank / Hardie Board siding ??? #25
i have never seen any screws for the hardie siding???? i will look closer the next time i am at one of the places that handles it..
heehaw
   / Hardie Plank / Hardie Board siding ??? #26
heehaw
I used Hardie screws. I cannot remember if they were REALLY supposed to used for their siding. I DID use them for their tile backer board. Seems like I might have had some left over Durorock screws that I might have used as well.
Do check and make sure that Hardie says to use the screws. I did because I had them left over and cement board is cement board. :D My installation is temporary as well. Course it has been temporary for about five years now and no replacement is even close to be affordable. :laughing:
Later,
Dan
   / Hardie Plank / Hardie Board siding ??? #27
Later,
Dan
I didn't know they made their own screws and I also didn't know whether screws would split the boards, so when I put house numbers on my daughter's mobile home, I did predrill holes, and used small regular screws.
   / Hardie Plank / Hardie Board siding ??? #28
To screw/nail you had to be 3/8" inch from the edge to keep the material from breaking. I remember that much. :D
I had to check the installation instructions. :laughing: These instructions look similar to what I used a few years ago. http://www.jameshardie.com/pdf/install/hardiepanel-hz5.pdf.
They mention fasteners and nails but no outright mention of screws. The backer board instructions mention using screws, http://www.jameshardie.com/homeowner/pdf/backer-install-us.pdf, which is what I had left over from a our bathroom refurb.
Tis kinda odd that they mention what size fasteners to use for the Hardibacker but not the panel product.
They need to review their documents. :D
The lapsiding instructions give a very nice fastener schedule including screws and nails. http://www.jameshardie.com/pdf/install/hardieplank-hz10.pdf :laughing: I have not noticed any rust from the Hardie screws I used. They were coated. I did not caulk or paint the screws. Just installed it let the weather have at it. :eek:
The screws would zip right in. If I had had a nail gun I would have use it. Maybe. I had no use for the screws and they were kinda specialized for cement board. :laughing: Waste Not, Want Not. :thumbsup::D
Later,
Dan
   / Hardie Plank / Hardie Board siding ??? #29
We've had Hardiplank and Hardipanel on our homes for about 12 years. My only issue with it is that my contractors can't seem to find a caulk that won't shrink after a few years. We could see a bit of housewrap for a while there.
   / Hardie Plank / Hardie Board siding ??? #30
That stuff is far superior to other siding products except maybe masonry.
I have the shears and they work great for straight cuts. I am still learning how to do the notches or holes for tricky cutouts.
Be careful, the dust it creates from saws is very bad for you. The shears produce no dust, just a curlycue of material as it cuts.
In the past, I used a jig saw. It ate blades pretty fast but the dust was a lot less.
I have been a big booster of the cement board since it came out. We used it when we put an addition on our house ten yeas ago, no regrets still holding the paint well. The contractor we used had the shears. That being said when it came time to put new siding on a small rental house I own we went with Louisiana Pacific's smart siding.LP Building Products | LP SmartSide Trim & Siding Family. Both the fellows at our local yard recommended it over the Hardi Plank. When asked why the yard manager said twenty years ago the Hardi Plank salesmen would drop a sample into a five gallon bucket of water and a month later you cold pull it out and and it would quickly dry off not having absorbed any water. He said they now use less cement in the mix and it no longer is as resistant to absorbing moisture as it used to be.
I am unsure if this is true but I dd spend a good deal of time going over the issue in some builder forums. I ran across some contractors who said much the same. Of course many made the point as some have here that proper installation no matter what you use is critical to success no matter what you use. My son did the installation. One point he picked up when he also went through the forums looking for tips was the importance of having the proper gap before caulking. He said it is important to have it wide enough that the caulk can work.
By this he means that the caulk will have the ability to contract or expand only a certain percentage of it's width, this will vary depending on the design and quality of the caulk. If the width of the gap is too small, say a 16th of an inch and the caulk has the ability to expand/contract 20% of that 16th of an inch, well you can see that it may easily split apart.
The proper caulk and the proper width of the seams therefore is critical to the success of the project. Also, going with the wider gap means you are using a great deal more caulk then you might if you just went by the seat of you pants and using the proper caulk likely will mean you are spending more money per tube. In short do not underestimate the additional cost of caulk no matter the product you chose.
We choose to use the LP smart siding with a pre-finish, barn red with white trim, Diamond Coat I believe. Our trim also came pre-finished. Another advantage to the smart siding was it was available in longer lengths and was not as brittle.
As of now happy with it, time will tell. I will note that the tip about the width of the seam to be filled is also relevant to caulking a tub or any other seam. I now pay more attention to the gaps I leave when installing tub and showers and how much gap I leave when i bring the flooring up to the tub.
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2006 Dewatering and Drying Centrifuge (A56857)
2006 Dewatering...
