Harman Coal Stoves
   / Harman Coal Stoves
Thanks for the replys and links. It should warm up later this week and I will let the stove burn out and try oven cleaner. Oven is self cleaning so I will have to go buy some... thought I had a can in the camper but didn't.
mark
   / Harman Coal Stoves #12
Where can you buy a stove like that ? How much ? And where do ya get the coal at.
We have an old Home Stead wood stove , it's about 20 years old.
The company went by - by.....
The old stove has seen it's better days.
I bought it used, one year old. $1600 stove for $700 with the optional hot water coil (not using). Coal is now $192 per ton so I don't burn unless it is really cold outside. 72,000 BTU's of pure heat. Burning coal is a lot different than wood. Cleaner but a lot more ash to deal with.
mark
   / Harman Coal Stoves #14
Most folks who burn coal in this area use the stokers. They are self feeding and use rice coal. There was a day when rice coal could be bought for $15 a ton because nobody used it, now it's close to $200 a ton. Coal is harder to start, I think the ignition temp for coal is around 900 degrees but once you get it going it produces a good steady heat. The stokers can be as small as 30,000 btu units and will go 60 hours before refilling the hoppers. I am using a 144,000 btu hotwater stoker that is heating a big old stone house and does a decent job. Seventeen years of constant running without one problem so it has been dependable.
Once I get the firebox heated to about 250 degrees using wood scraps, I can get hard nut coal to ignite. Stove pipe temp runs 300 - 500 degree range.
mark
   / Harman Coal Stoves #16
I just got a price from a store about 2 hrs from our home...
They said they could get 1 sent to our home for around , ( you better be setting down )....... $ 2700.00........... Is this right ??? , it must be one really good stove.
I found some coal on a pallet at my local Tractor Supply, last year for about $ 275.00 Ton.....
I like the idea of not having to build a fire every day with wood, and the coal stove burns up to 6 or 8 days, Self feed,
Corn is out of the question, it's around $11.50 a 100#, and on the rise..
We burned over 3 cords of wood so far,this year, we may have an early spring, the trees are starting to bud out.
I like that stove , BUT....... $2700.00.....??????? OUCH >>>>>>>>
Mine is not high tech... I use a shovel to load and shake the grates by hand... $2700 is probably about right for a self feed hopper rice coal burner.
mark
   / Harman Coal Stoves #19
Killer,
what kind of temps do you want to run the stove in?
do you get and stay below freezing?
I know with my hand fired stove, when the temps
stay above 40, it's time to shut down, as I can't
really run my stove too low. I know it's different
with a stoker that has electronic controls.
You said they have a pallet of coal, would more
be readily available down the road?
1831 (A51247)
1831 (A51247)
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2018 INTERNATIONAL...
Peterbilt (A51692)
Peterbilt (A51692)
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
