Stuka
Harvey came and my JD zero turn 757 lawnmower that was submerged in 4ft water for 8 days. I got it back to the house today and drained the engine oil, filled the crankcase with fresh oil and drained it again, then changed the filter and added the normal amount of oil. I siphoned all the gas/water from the fuel tank, and bled the fuel line. I removed the spark plugs and siphoned what water I could from the cylinders, and sprayed WD-40 in. I will drain the hydraulic oil and change the filter, and replace the fuel filter and air filter element. Last, I will replace the battery. I'll crank it over until I have displaced any residual water from the combustion chambers, then put the plugs back in and add fresh fuel.
Anything I am missing? Wish me luck!
