Did water enter the hydraulic reservoir tank?
Did you see any water in the filter? (Cut it open.)
I think some water did make its way into the reservoir, but not much.
Well, got off work and yep, all the oil drained out through the filter fitting, crazy that is drains so slowly. Anyway, put the new filter on and added two gallons of cheap O'Reilly motor oil to the reservoir for the initial run.
I looked over the carb to see if I could drain the bowl but it appears to be connected to the engine by magic, I can't see an easy way to remove it, so I sprayed some carb cleaner through the air inlet and said a prayer. Replaced the fuel filter then connected the new battery and turned the key... nothing.
Oh right, it has an interlock with the parking brake, so I moved the brake handle to the Park postion, turned the key and it spun nicely, throwing out a fine mist from the plug holes. Yes! I screwed the plugs back in and with my Papa hitting the carb with well timed spurts of starter fluid, it fired up and chugged to life. After a few minutes the engine smoothed out real nice like, so I threw the handles forward and away we went. I made some technical maneuvers, mostly right and left and circle, to give the hydraulics a whirl, then engaged the PTO. The engine slowed way down, almost died, but managed to keep going, the blades spun without mishap.
I let the engine run for another 10 minutes, then put her up. I'll get the new air filter when it comes in, run it again and then change oil and hydraulic oil again, and grease the **** out of it. Yay!
