Has anyone built a brush rake?
   / Has anyone built a brush rake? #11
I never had on for my big dozer. So the day I got my D4 I ordered a rake. I did not build mine with the price of steel I would not have saved that much. It is around 1500lbs 10.5' wide 11 teeth at 1 1/4" thick. The tubing is 5x5 1/2 wall. Shipped to me it was $1950.00. They have them all sizes.
http://www.dozer-rake.com/
I also added the sweeps, exhaust hat and screens.
[image]
[/image]
[image]
[/image]
John
   / Has anyone built a brush rake? #12
I just stumbled across this old post
To answer some questions
That is a early Rogue Fabrication Rake (the first pic)
Yes its a Komatsu E-21P-6 To be exact (mine)
   / Has anyone built a brush rake? #13
This works for a small tractor, mostly for loose sticks and stuff that's laying on the ground. Home-built mini-rakes attached to a home-built brush fork.
   / Has anyone built a brush rake? #14
My grapple works great as a brush rake and ground scraper.
   / Has anyone built a brush rake? #15
Yes I can see that it would. It reaches pretty far out. I bet that grapple would tip my little tractor up on its front wheels!
My preference is to have the brushfork below (as is), and my stick-rakes on a grapple hand (another brushfork) coming down from above. Essentially a very light-duty grapple, not suitable for stumps or rocks, but specifically for cleaning up sticks and making burn piles. I have a LOT of sticks.
I have been thinking about the amount of pressure that I want on the ground from my rake, and have decides it's better if it doesn't dig up the existing grass, because that gives the weeds an advantage to grow instead.
Last time I was out, I had to
1) Scrape up piles of sticks (by reversing)
2) Push them up into higher piles (carefully pushing forward with rakes)
3) Remove rakes from the brushforks and carry sticks to the burnpile (with the brushfork)
4) Remove the brushforks and scoop with the bucket; dump the small stuff over a bank.
I cleaned up a large area quickly like this.
Before, there were lots of sticks and dead bushes (= more sticks) with grass & weeds tangling thru all this, all trying to get some sun. It takes until mid summer for the grass to get about a foot tall and start to cover the sticks and stuff, so it finally appears greener than the sticks in late June. So it just looks trashy for most of the spring.
Now (fall) it looks nice and finished and the ground is not too disturbed, and if any sticks they are small and laying flat on the ground. In the springtime once the grass is 3 inches tall there will be no sticks or dirt visible and it will look "green". Anyway thats the look I want.
   / Has anyone built a brush rake? #16
Sodo,
That's a great set up you built. I've seen some Grapple arm kits for small tractors that would make moving that around easy. Keep doing what you are doing, the ground you cleaned looks great !!!
   / Has anyone built a brush rake? #17
Some of those smaller ones look similar to the pond rake I built.
   / Has anyone built a brush rake? #18
JWmorris, Do you have any more pictures/build details on that pond rake?...I have a pond to muck out that looks pretty slick.
   / Has anyone built a brush rake? #19
Skylark, there are some more photos in this album. Farm Photos by jmorrismetal | Photobucket
All of the extra bracing came from the water primrose draping over the rake on the first try and bending the pipe once out of the water and not comming off. With the bracing it didn't bend the pipe but broke the home made top link, due to all of the extra weight. The old desk top kept the weeds from looping over the rake and now they just fall off when you lift and it works great.
   / Has anyone built a brush rake? #20
how about something like this
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
TOYOTA 8FGCU30 FORKLIFT (A52472)
TOYOTA 8FGCU30...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
7046 (A50322)
7046 (A50322)
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
