tessiers
Platinum Member
- Joined
- Sep 22, 2007
- Messages
- 727
- Location
- Central Maine
- Tractor
- 05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I've done a fair amount of concrete work in my life both professionally and home work.
Portland cement is only a bonding agent. It adheres what is called aggregate together. Aggregate is sand, stone, fly ash, ect. Cement will not bond to organic and un-stable materials. The fact that the granite is decomposing should give the clue that it is not a acceptable aggregate. It will continue to decompose and cause breaks in the concrete. I would not even consider using dirt or even dirty soil. The sand and stone used in most mixing plants is washed before use. How much are you really going to save, $10 or $15 per yard will seem insignifigant when you are trying to fix the results.
I poured a slab 16x22 a couple of years ago with a portable mixer, it was not pretty. The small batches set up at different rates making it next to impossible to finish.
Redi mix concrete is about $100 per yard.
Protland cement is about $7 per bag times 5
Sand or gravel about $12 per yard
$50 dollars per yard to mix it yourself, at 3 to 6 cubic feet at a time
For less than a yard mix it at home with good materials but large amounts call a Truck.
Just My 2 cents, take it for what its worth.
